Plantronics M12E/A Vista Adaptor
Now there's an easy answer to all your hands-free communication needs - the Vista Universal Amplifier. Vista is easy to use and works with your choice of Plantronics headsets to deliver precise levels of listening and talking comfort, superior protection, and excellent audio performance. Vista includes near-universal compatibility with single- and multi-line telephones, as well as ergonomically designed Volume, Headset / Handset and Mute controls. The Quick Disconnect between the adapter and the headset allows you to move away from your phone without removing the headset or disconnecting the call.
| Ref | Condition |
| 6MG4 749 | Used. |
£75.25 | |
| 6MG4 702 | Unused, not in original packaging. |
£75.25 | |
| 6MG4 1165 | Used. |
£41.80 |
All used stock has a 90 day warranty
