Click to visit BT.com
Peerless Tru Vue TRPRJF-S - Mounting kit ( ceiling mount ) for projector - silver
Peerless Peerless Tru Vue TRPRJF-S - Mounting kit ( ceiling mount ) for projector - silver
Usually dispatched within 3 working days
Quicklinx: 7L8MWS00
Mfr#: TRPRJF-S
£30.90
Universal spider fitting pattern with full movement of arms
Low profile drop of 150 mm from ceiling
Ideal for discrete installations
Projector mount with full 360° swivel for quick and easy re-positioning
Ball joint adjustment allows for flexible image alignment up to 30° in all directions
Tool-less knobs for manual adjustment and set screws for tamper-resistance
Installs direct to concrete ceiling or wood beam
Manufactured from high quality steel for solid construction with scratch resistant powder coated finish
Peerless Tru Vue TRPRJF-S - mounting kit
15 cm
Adjustable Width
24.5-33 cm
Adjustable Depth
24.5-33 cm
Silver
AV Furniture
Mounting kit
Mounting Components
Ceiling mount
Recommended Use
Projector
Max Mounting Pattern Size
33 x 33 mm
Max Load Weight
10 kg
Scratch-resistant, swivel adjustment
feature value
Type [N/A]
Portability Non-portable
Brand Peerless
Price Range Inc VAT 0 - 50
