Click to visit BT.com
Panasonic Vertical Polyester Case-Black
Panasonic Panasonic Vertical Polyester Case-Black
20 Left In Stock
Quicklinx: 6448WS00
Mfr#: VW-PS57XE-K
£19.84
The PS57 is a polyester carrying case designed to fit and protect specific Panasonic standard and high definition camcorders. This is a "just-fit" design for when you do not want to carry larger, more awkward bags. The external material is both strong and durable but not waterproof.
Camcorders are valuable and need to be wrapped up in cotton wool - so why not look into the VW-PS57XE-K Camcorder Case from Panasonic. This vertical polyester case protects your camcorder from damage. Parties, holidays, mountain hikes - take your precious equipment anywhere, without the worry of scratching or breaking it.
The non-abrasive interior of the black VW-PS57XE-K Camcorder Case will keep your camcorder in pristine condition as well. It comes equipped with shoulder strap and belt loop so you can carry it around securely and in comfort.
Shield your camcorder from hard knocks with the durable VW-PS57XE-K Camcorder Case.
Image gallery
Select any thumbnail below to view a larger image.
Panasonic VW-PS57XE-K - case camcorder
Case camcorder
Material
Polyester
Panasonic SDR-H80, SDR-H90, SDRS26, SDR-S26
Material
Polyester
Carrying Case
Case
Recommended Use
Camcorder
Panasonic SDR-H80, SDR-H80A, SDR-H80EB-S, SDR-H80EC9-A, SDR-H80EC9-K, SDR-H80EC9-R, SDR-H80EC-A, SDR-H80EC-K, SDR-H80EC-R, SDR-H80EC-S, SDR-H80EF9-K, SDR-H80EF9-R, SDR-H80EF-A, SDR-H80EF-K, SDR-H80EG9-A, SDR-H80EG9-K, SDR-H80EG9-R, SDR-H80EG9-S, SDR-H80EG-A, SDR-H80EG-K, SDR-H80EG-R, SDR-H80EG-S, SDR-H80EP9-K, SDR-H80EP9-R, SDR-H80EP9-S, SDR-H80EP-A, SDR-H80EP-K, SDR-H80EP-R, SDR-H80EP-S, SDR-H80K, SDR-H80PU-A, SDR-H80PU-K, SDR-H80PU-R, SDR-H80PU-S, SDR-H80R, SDR-H80S, SDR-H90, SDR-H90EF9-K, SDR-H90EG9-K, SDR-H90EP-K, SDR-H90K, SDR-S26, SDRS26/B, SDR-S26A, SDR-S26EB-A, SDR-S26EB-K, SDR-S26EB-N, SDR-S26EB-R, SDR-S26EC-A, SDR-S26EC-K, SDR-S26EC-N, SDR-S26EC-R, SDR-S26EF-A, SDR-S26EF-K, SDR-S26EF-R, SDR-S26EG-A, SDR-S26EG-K, SDR-S26EG-N, SDR-S26EG-R, SDR-S26EP-A, SDR-S26EP-K, SDR-S26EP-N, SDR-S26EP-R, SDR-S26K, SDR-S26N, SDR-S26PU-A, SDR-S26PU-K, SDR-S26PU-N, SDR-S26PU-R
feature value
Brand Panasonic
Stock Status Clearance
Price Range Inc VAT 0 - 50
