Click to visit BT.com
Optoma DS211 - DLP Projector - 2500 ANSI lumens - SVGA (800 x 600) - 4:3
Optoma Optoma DS211 - DLP Projector - 2500 ANSI lumens - SVGA (800 x 600) - 4:3
1 in stock
Quicklinx: 7KTCWS00
Mfr#: DS211
£236.82
Get ready... to bring the big picture experience into your home with the ultra-bright DS211. Easy to use, this small and stylish projector gives you the possibility of a huge 300" image, to bring the cinema viewing into your own home.
Share your holiday photos with your friends and family, watch the latest blockbuster movie, enjoy the big game or just simply use it as backdrop for your party, the Optoma DS211 is the perfect multi-use projector for your home.
Hassle-free, long lasting projection with the 6000 hour lamp-life, filter-free low maintenance design combined with our unique Optoma Colour and Imager guarantees.
Get Connected
Easy to use with most of your home devices; simply connect, power up and project from:
-Satellite and cable Set top boxes
-Computers and laptops
-DVD players
-Games consoles
-Television recorders
-External speakers/Headphones
Clear, Focused Images
DarkChip3â„¢ technology from Texas Instruments produces a stunning 3500:1 contrast ratio for pin sharp, crystal clear images. Crisper whites and ultra rich blacks bring the image to life.
Virtually Maintenance Free
The DS211 provides lower cost of ownership, longer life and improved reliability. The filter-free projector design does not require regular filter cleaning or filter replacement, saving you time and money.
Amazing Colours
The DS211 incorporates BrilliantColorâ„¢ technology to produce stunningly bright images with perfectly balanced life-like colours. Preset display modes allow you to achieve a perfect image every time.
Colour and Imager Guarantee
Bright colours and fantastic image quality are guaranteed for an amazing 5 years after purchase - giving piece of mind that the technology inside the Optoma DS211 projector won't fade or degrade.
Environmentally Friendly
The DS211 incorporates energy saving features to conserve power and extend the lamp life:
To achieve the maximum 6000hrs** lamp life time the projector should be operating in ECO mode and the shut down timer should be enabled to automatically switch off the projector if it is accidentally left on when no longer required. Enabling the <1W Standby mode will ensure the minimum energy consumption when the projector is not being used. It takes less than 10 seconds for the projector to power up and shutdown, saving both time and energy.
Image gallery
Select any thumbnail below to view a larger image.
DLP Projector
28.6 cm x 19.2 cm x 8.4 cm
2.3 kg
Image Brightness
2500 ANSI lumens
Image Contrast Ratio
3500:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
180 Watt
Bulb life cycle
5000 hour(s) / 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video ( NTSC, SECAM, PAL )
Video Modes
480p, 720p, 1080i, 480i, 525i, 525p, 625p, 625i, 576i, 576p
Video Output
RGB
Input Device
Remote control
AC 120/230 V ( 50/60 Hz )
233 Watt
5 years warranty
DLP Projector
28.6 cm
19.2 cm
8.4 cm
2.3 kg
Projector / Panel
Image Brightness
2500 ANSI lumens
3500:1
Image Size
70 cm - 770 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.95 - 2.15:1
Uniformity
80 %
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
180 Watt
Bulb life cycle
Controls & Adjustments
Volume, brightness, contrast, keystone correction, zoom
OSD Languages
Danish, Hungarian, Czech, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic
BrilliantColor, 16:9 aspect ratio support
Projector Lens System
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue Video Format
NTSC, SECAM, PAL
Analogue video Signal
Video Modes
Video Output
Analogue Video Signal
RGB
Input Device
Remote control - external - wireless
Movement Detection Technology
Infrared
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 PIN mini-DIN , 1 x composite video input - RCA , 1 x serial RS-232 - 3 PIN mini-DIN ( management )
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS
Power supply - internal
233 Watt
Power Consumption Operational ( Standby )
1 Watt
5 years warranty
Service & Support Details
Limited warranty - 5 years , Limited warranty - lamp - 6 months
5 °C
0 - 85%
Sound Emission
30 dB
28 dB
feature value
Type DLP Projector
Brightness 2500ANSI lumens
Contrast Ratio 3500:1
HD Format [N/A]
Portability Portable
Resolution 800 x 600
Brand Optoma
Stock Status In Stock
Price Range Inc VAT 150 - 300
