Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
OKI C810dn A3 Colour Laser Printer
Quicklinx: 5DVDWS00
Mfr#: 01235401
Essential accessories
The OKI C810DN from OKI Printing Solutions. Small footprint. Giant step forward in business A3 printing.
Never before has fast, A3 color printing been so outstandingly affordable and remarkably small. Especially one that can be networked. It's a groundbreaking combination from the specialists in printed communications for business.
The OKI C810DN is a revolution in A3 color printing, packing outstanding features into a uniquely small footprint that is almost half the size of other A3 color printers in its class.
It delivers high quality, highly affordable printing in both A4 and A3, color and mono. It occupies minimal space and offers fast and flexible media handling. It has built in reliability, full networking capability and easy to use controls. Guaranteeing that there is one to suit your business and your budget.
  • Affordable
    A major win in cost vs performance. This high quality, highly affordable printer gives low cost color printing whilst maintaining low mono costs per copy.
  • Compact
    The most compact A3 color printer available. At half the size of other A3 printers, compact and quiet, it can sit close to the desktop for extra convenience, while saving floor space.
  • Versatile
    Print a range of document sizes and formats with ease on a range of media, from postcards to banners. Duplex capability allows double-sided printing including booklets, whilst Template Manager 3.0 enables the creation of a range of professional-looking documents in-house.
  • Fast
    Enhance business efficiency with fast time to first page of just 10 seconds and high print speeds of 30ppm A4 color and 32ppm A4 mono will help maintain business momentum.
  • High definition color
    Print quality will visibly enhance documents across the business. Every color document benefits from ProQ2400 Multi-level technology and unique microfine High Definition Toner. Photo Enhance, selectable within the driver, allows you to print impressively sharp, photo-like pictures on ordinary office paper.
  • Easy to use
    With its simple controls and smooth paper flow, the C810DN requires minimal user attention.
  • Easy to control
    Print Control enables the management of color use and printing costs of each individual user.
  • Reliable
    With single pass digital LED technology, paper handling is smooth across all media. The straight paper path minimizes the need for user attention and maintains the workflow.
OKI C810DN - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
40 kg
Max Media Size (Standard)
A3, Ledger
Print Speed
Up to 32 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 17 ppm - B/W - A3 (297 x 420 mm) , Up to 16 ppm - colour - A3 (297 x 420 mm)
Max Resolution ( B&W )
1200 x 600 dpi
Max Resolution ( Colour )
1200 x 600 dpi
Image Enhancement Technology
OKI ProQ2400 Multilevel
Automatic Duplexing
USB, LAN
PowerPC 405 200 MHz
RAM Installed ( Max )
128 MB ( 128 MB )
Language Simulation
Windows GDI driver
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper, banner paper
Total Media Capacity
400 sheets
Media Handling
100-sheet multipurpose tray, 300-sheet input tray
Monthly Duty Cycle (max)
75000 pages
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Single Pass Colour Digital technology
AC 230V
Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X on Intel 10.4.4 or later, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Apple MacOS X 10.5, Microsoft Windows Server 2008 x64 Edition
Microsoft Certification
Compatible with Windows 7
3 years warranty
48.5 cm x 63.4 cm x 34.5 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN
1200 x 600 dpi
1200 x 600 dpi
Automatic Duplexing
First Print Out Time B/W
9.5 sec
First Print Out Time Colour
10 sec
Language Simulation
Windows GDI driver
Printer Features
Media Handling
PowerPC 405 200 MHz
RAM
128 MB / 128 MB (max)
Media Handling
Media Type
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Com-9 (98 x 225 mm)
Media Weight
64 g/m2 - 220 g/m2
400 sheets
Media Feeder(s)
1 x autoload - 100 sheets weight: 64 g/m2 - 220 g/m2 , 1 x autoload - 300 sheets weight: 64 g/m2 - 120 g/m2 , 2 x optional autoload - 530 sheets weight: 64 g/m2 - 176 g/m2
Max Media Capacity
1460 sheets
Output Trays Capacity
350 sheets
Duty Cycle
75000 pages
Print server - internal
Expansion Slot(s)
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 PIN USB Type B
Consumables Included
1 x toner cartridge ( black ) - up to 2000 pages at 5% coverage , 1 x toner cartridge ( cyan ) - up to 2000 pages at 5% coverage , 1 x toner cartridge ( magenta ) - up to 2000 pages at 5% coverage , 1 x toner cartridge ( yellow ) - up to 2000 pages at 5% coverage , 1 x drum ( black ) - up to 20000 pages , 1 x drum ( cyan ) - up to 20000 pages , 1 x drum ( magenta ) - up to 20000 pages , 1 x drum ( yellow ) - up to 20000 pages
Supported Windows 7 Features
Windows HD Imaging
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
570 Watt
Power Consumption Stand by / Sleep
200 Watt
Software Included
OKI LPR, OKI Print Control Client, OKI Print Control Server, OKI PrintSuperVision.net, OKI Swatch Utility, OKI Web Driver Installer, OKI Web Print, OKI Color Correct, OKI Template Manager 3.0
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 °C
32 °C
20 - 80%
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
54 dBA
48.5 cm
63.4 cm
34.5 cm
40 kg
