Click to visit BT.com
OCZ Technology PSU, ModXStream Pro, 700W - UK
OCZ Technology OCZ Technology PSU, ModXStream Pro, 700W - UK
15 In stock
Quicklinx: 5D16WS00
Mfr#: OCZ700MXSP-UK
£62.98
The ModXStream Pro Series is the superlative solution for driving today's gaming systems, and can power both NVIDIA SLI and ATI CrossFire modes. Professional-grade yet designed with gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and compact form factor. Kept ultra-cool with a load-controlled 135mm fan, the ModXStream Pro was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 86% efficiency at typical load and up to 82% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load.
As a gamer or case modder, modular cabling is a necessity when building a cool and orderly system. To optimize airflow and eliminate cable mazes, the ModXStream Pro is equipped with EZMod technology to allow complete customization of your power system by utilizing only the cables you require.
The OCZ ModXStream provides universal input and active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
Image gallery
Select any thumbnail below to view a larger image.
OCZ ModXStream Pro power supply - 700 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2/ EPS12V
15 cm x 16 cm x 8.6 cm
United Kingdom
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Connector(s)
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V , 1 x power 4 pin ATX12V connector , 1 x 6 pin PCI Express power , 1 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector , 6 x 15 pin Serial ATA power
3 years warranty
ATX12V 2.2/ EPS12V
15 cm
16 cm
8.6 cm
United Kingdom
Input Voltage Range
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
700 Watt
Output Current
+5V - 25 A , +3.3V - 25 A , +12V1 - 25 A , +12V2 - 25 A , -12V - 0.3 A , +5VSB - 2.5 A
MTBF
100,000 hour(s)
Active Power Factor Correction (PFC) , over voltage protection, overpower protection, SLI ready, CrossFire ready, cable management, short-circuit protection
3 years warranty
Service & Support Details
Limited warranty - replacement - 3 years
feature value
Power Rating 700Watt
Brand OCZ Technology
Stock Status In Stock
Price Range Inc VAT 50 - 100
