Click to visit BT.com
Nikon Coolpix L23 Digital Camera - Pink
Nikon Nikon Coolpix L23 Digital Camera - Pink
1 Left In Stock
Quicklinx: 7JJ6WS00
Mfr#: VMA753E1
£64.99
The perfect camera for anyone just starting out in photography, the COOLPIX L23 boasts a host of automatic technology for perfectly effortless shooting.
Wherever you are and whatever you want to shoot, Easy Auto Mode optimizes all camera settings for superior results, making it simple to capture the shot you want.
The wide-angle 5x zoom lens lets you capture everything from sharp close-ups to stunning group photos with ease, and Nikon's Smart Portrait System ensures perfect portraits every time. Compatible with AA-size batteries and boasting a slim body, it's easy-to-power and easy-to-carry anywhere.
The COOLPIX L23 - A great way to start.
Easy operation
Conveniently placed control buttons and helpful automatic technology for effortless shooting.
NIKKOR wide-angle 5x zoom lens
Offers outstanding precision and sharp resolution. (35mm equivalent: 28-140mm).
10.1 megapixel CCD image sensor
Lets you capture outstandingly detailed images and produce stunningly sharp enlargements.
3x anti-blur automatically counters blurred images in three different ways:
Electronic VR (Vibration Reduction) reduces the effect of camera shake.
Motion detection compensates for camera and subject movement.
Best Shot Selector (BSS) automatically selects the sharpest of up to 10 sequential shots.
Generous 6.7 cm (2.7-in.) LCD monitor
With brightness boost function to enhance visibility.
Smart portrait system - advanced automatic features for perfect portraits:
Smile Timer takes the shot when your chosen subject smiles.
Blink Proof alerts you when someone had their eyes closed.
Skin softening adjusts uneven skin tones on people's faces for smoother looking skin.
In-camera Red-eye Fix corrects false eye color due to flash the instant you take the shot.
Easy Auto mode
Optimizes all camera settings according to the light you are shooting in.
Powered by two AA-size batteries: making it easy to replenish your camera's power source, no matter where you are.
17 scene modes
Automatically optimize settings for popular photographic styles, effects and locations.
EXPEED C2:
Nikon's advanced image processing system optimizes all camera technologies for superior performance and maximum image quality.
Image gallery
Select any thumbnail below to view a larger image.
Nikon Coolpix L23 - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
EXPEED C2
Sensor Resolution
10.1 Megapixel
Max Video Resolution
640 x 480
Lens System
5 x zoom lens - 4 - 20 mm - f/2.7-6.8
Focus Adjustment
Automatic
Min Focus Range
30 cm
Digital Zoom
4 x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
2 x AA alkaline battery ( included ) , 2 x AA lithium battery ( optional ) , 2 x AA NiMH rechargeable battery ( optional )
AV Interfaces
Composite video/audio
Microsoft Certification
Compatible with Windows 7
Pink
9.7 cm x 2.9 cm x 6 cm
170 g
Enclosure Colour
Pink
Sensor Resolution
10.1 Megapixel
Optical Sensor Type
CCD
Total Pixels
10,390,000 pixels
Effective Sensor Resolution
10,100,000 pixels
Optical Sensor Size
1/2.9"
Digital Zoom
4 x
Image Processor
EXPEED C2
Image Stabiliser
Electronic
Auto Focus
TTL contrast detection
Image Recording Format
JPEG
640 x 480
AV Interfaces
Exposure & White Balance
Light Sensitivity
ISO auto (80-1600)
Exposure Modes
Programme, automatic
Lens System
Focal Length Equivalent to 35mm Camera
28 - 140mm
Focus Adjustment
Automatic
Min Focus Range
30 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 6 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Additional Features
Additional Features
Audio recording, direct print, RGB primary colour filter, PictBridge support, digital image stabilization, Smile Detection Auto Shutter, Scene Detection Technology, in-camera red-eye fix, face-priority AF function, Best Shot Selector (BSS), face detection, Blink Detection technology, Motion Detection Technology, Smile Detection technology, Scene Auto Selector
Display
2.7" LCD display
Resolution
230,000 pixels
Display Features
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x Hi-Speed USB , 1 x composite video/audio output
Memory Card Slot
SD card
Software
Software
Drivers & Utilities, Nikon ViewNX 2
System Requirements for PC Connection
Peripheral Devices
USB port, CD-ROM Drive
Carrying strap, USB cable
Battery Type
AA
Details
Memory / Storage
RAM Installed
22 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 3648 x 2736 , JPEG 3264 x 2448 , JPEG 2592 x 1944 , JPEG 2048 x 1536 , JPEG 1024 x 768 , JPEG 640 x 480 , JPEG 3584 x 2016
Video Capture
640 x 480 - 30 fps , 320 x 240 - 30 fps
9.7 cm
2.9 cm
6 cm
170 g
feature value
Type Compact
Resolution 10.1Megapixel
Optical Zoom 5
Colour Pink
Brand Nikon
Stock Status In Stock
Price Range Inc VAT 50 - 100
