Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
NetGear Universal WiFi Range Extender
Quicklinx: 72GRWS00
Mfr#: WN2000RPT-100UK
Standard delivery Delivered within 3 working days once we receive stock
The NETGEAR Universal WiFi Range Extender allows you to keep your current wireless equipment and improve wireless coverage to eliminate dead zones. It is compatible with wireless b/g/n routers, gateways and Internet service provider devices. It allows freedom to roam anywhere in the house and access Internet without worrying about coverage. A bonus feature is 4 Ethernet ports to connect to gaming consoles, Internet TV's, and Blu-ray players. A real-time link-rate LED locates the best placement spot to provide optimal wireless coverage and a graphical guide makes installation easy. There's no need to insert a CD or plug in Ethernet cables!
  • Keep your current wireless equipment and improve coverage to eliminate `dead zones'
  • Compatible with wireless b/g/n routers, gateways and Internet Service Provider`s devices
  • Freedom to roam anywhere in the house and access Internet without worrying about coverage
  • Bonus feature--4 Ethernet ports to connect to gaming consoles, Internet TV's, and Blu-ray players
  • Works with any wireless b/g/n router or gateway from NETGEAR and other brands
  • Works with all security standards including WPA-PSK, WPA2-PSK, mixed mode and WEP
  • Real-time link-rate LED locates the best placement spot to provide optimal wireless coverage
  • Step-by-step, graphical Installation Guide makes installation easy. No need to insert a CD or plug in Ethernet cables!
  • Dynamic LEDs display live network connection status and signal strength between your existing network, Extender and computers (or other Internet-connected devices)
  • Push `N' Connect using Wi-Fi Protected Setup™ (WPS) connects computers to the Extender quickly and securely1
  • Four (4) Ethernet ports allow the Extender to function as a wireless bridge to connect to home AV devices
NETGEAR WN2000RPT Universal WiFi Range Extender - wireless network extender
Wireless network extender
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Vertical stand
17.8 cm x 13 cm x 3.5 cm
0.68 kg
17.8 cm
13 cm
3.5 cm
0.68 kg
United Kingdom
External
Wireless
Frequency Band
2.4 GHz
Status Indicators
Status
Wi-Fi Protected Setup (WPS), wireless bridge mode
Encryption Algorithm
WPA-PSK, WPA2-PSK
4 x 100Base-TX - RJ-45
Vertical stand
External power adapter
Resources
The following resources are available for the NetGear Universal WiFi Range Extender
