Click to visit BT.com
NetGear ProSafe 16-port Fast Ethernet Switch
NetGear NetGear ProSafe 16-port Fast Ethernet Switch
Quicklinx: 6KGFWS00
Mfr#: FS116E-100UKS
NETGEAR's popular FS100 series desktop switches, known for its reliability and performance, provide your LAN with high-speed, 10/100 Mbps auto-sensing connectivity for 16 users. Just plug in your Ethernet cables, connect a power cord, and you're ready to go-there's no software to configure. They negotiate to the fastest possible connection and with Auto Uplink technology, these switches automatically figure out if the link needs a straight through or cross-over connection, and makes the right choice. Existing 10BASE-T devices are easily integrated within higher bandwidth environments, with full wire speeds on all ports of either 10Mbps or 100Mbps. Engineered without the need for internal fans, they operate silently. And each of these very compact switches is housed in a sturdy metal case for years of dependable use.
Resources
The following resources are available for the NetGear ProSafe 16-port Fast Ethernet Switch
NETGEAR ProSafe Plus FS116E 16-port Fast Ethernet Switch - switch - 16 ports - desktop
Switch - 16 ports
Enclosure Type
Desktop
Ports
16 x 10/100
MAC Address Table Size
4K entries
Flow control, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x
28.7 cm x 10.3 cm x 2.7 cm
0.81 kg
Microsoft Windows Vista / XP
United Kingdom
NETGEAR lifetime warranty
Switch - 16 ports
Enclosure Type
Desktop
Ports
16 x 10/100
4K entries
Status Indicators
Link activity, port transmission speed, power
16 x 10Base-T/100Base-TX - RJ-45
Power adapter - external
5.46 Watt
28.7 cm
10.3 cm
2.7 cm
0.81 kg
Mounting Kit
Included
MTBF
4,046,880 hour(s)
CE, C-Tick, EN 60950, EN55022, VCCI Class A ITE, CISPR 22, CB, FCC Part 15 A
United Kingdom
Software Included
Drivers & Utilities
50 °C
0 - 90%
