ITEM | QTY | PRICE |
Poly Plantronics EncorePro HW510 Nois...
4 | £236.48 |
Intelligent Edge M4100 series consists of 12 fully managed switches ranging from 8-port Fast Ethernet to 50-port Gigabit Ethernet. They are ideal for all organizations considering reliable, affordable and simple access layer switching with CLI scripting, Layer 3 static routing as well as PoE scalability. As a cost-effective component of converged voice, video and data networking solutions, NETGEAR M4100 series delivers a secure, intelligent edge in commercial buildings and large campus LAN environments. PoE (802.3af) and PoE+ (802.3at) versions of M4100 series are perfect for Wireless access points, IP telephony, CCTV and video-surveillance deployments.
Product Description | NETGEAR M4100-26G-PoE - switch - 26 ports - Managed - rack-mountable | Device Type | Switch - 26 ports - L2+ - Managed | Enclosure Type | Rack-mountable 1U | Subtype | Gigabit Ethernet | Ports | 26 x 10/100/1000 + 4 x shared SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 192 W | Performance | Bandwidth: 52 Gbps | MAC Address Table Size | 16K entries | Routing Protocol | Static IPv4 routing | Remote Management Protocol | SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, SSH, CLI | Features | Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, store and forward, Broadcast Storm Control, IPv6 support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, RADIUS support, MLD snooping, IPv4 support, LACP support, DHCP client, MVR, CoS | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 25.7 cm x 4.32 cm | Weight | 3.79 kg | Localisation | Canada, United States, Europe | Manufacturer Warranty | NETGEAR lifetime warranty |
General | |
Enclosure Type | Desktop, rack-mountable 1U |
Authentication Method | RADIUS, TACACS+ |
Status Indicators | Port status, power, RPS (Redundant Power Supply), PoE, fan |
Expansion / Connectivity | |
Interfaces | 24 x 1000Base-T RJ-45 PoE+ , 2 x 1000Base-T RJ-45 , 4 x SFP (mini-GBIC) , 1 x USB - 4 pin USB Type A , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 272.9 Watt |
Features | Redundant Power System (RPS) connector |
Miscellaneous | |
Rack Mounting Kit | Included |
Compliant Standards | CISPR 22 Class A, cUL, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, CB, CCC, FCC Part 15 A, C-Tick Class A |
Software / System Requirements | |
Software Included | Drivers & Utilities |
Dimensions & Weight | |
Width | 44 cm |
Depth | 25.7 cm |
Height | 4.32 cm |
Weight | 3.79 kg |
Manufacturer Warranty | |
Service & Support | NETGEAR lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 70 °C |
