Click to visit BT.com
NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g
NetGear NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g
Quicklinx: 2VCDWS00
Mfr#: DG834G-500UKS
Customer rating
5.0*
View reviews
Wireless Connectivity
The DG834G 54 Mbps Wireless ADSL modem router provides continuous, untethered access to network resources and the Internet. The DG834G allows you to share your hi-speed ADSL broadband connection wirelessly with all the desktop PC’s, laptops and games consoles in the household or small office. A built-in 4 port switch also enables you to connect some computers using cables if you prefer.
Safe and Secure
The built-in True Firewall features Stateful Packet Inspection (SPI) and Denial of Service (DOS), which operate as your first line of attack against intruders. The DG834G provides both WEP and WPA-PSK wireless encryption standards to protect your network from eavesdroppers and bandwidth pinchers! Content filtering lets you control access to inappropriate websites and limit usage by time of day. To be ultimately secure you can limit access to designated computers using their unique ID, called a MAC address.
Easy to Set-up
The DG834G 54 Mbps wireless router is simple to use – it plugs directly into your ADSL line, no need for a separate modem. Set-up could not be easier; NETGEAR’s Smart Wizard install assistant automatically detects and makes the best connection to your ISP (Internet Service Provider). It is also easy to change the settings of your DG834G wireless router via a web-browser interface.
Image gallery
Select any thumbnail below to view a larger image.
Customer reviews read all 72 customer reviews
Write a review for the NetGear DG834G Wireless BT ADSL Modem/Router & Firewall 802.11g here!
Excellent
Reviewed by RB. Review Posted 08/02/2005
Great product. Easy to configure, was up and running within minutes. Found the interface very easy to use with plenty of user help. No problems with the connection, and the wireless side of things works great.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
good piece of kit
Reviewed by Anonymous Review Posted 03/12/2004
Used several of these with no real problems. It does seem to drop signals if used with 802.11b devices but if used with 802.11g I find this router excellent. Easy to setup.
I use non netgear USB network sticks if I need to get a system repair online, simply because I get them much cheaper and performance is excellent, so using matched netgear network cards should be a breeze.
Don't seem to have any problems with my ipaq (4150) dropping signals though and that is 802.11b.
On the whole a good piece of kit.
  • Overall 5*
  • Ease of use 5*
Good stuff
Reviewed by Bennie. Review Posted 19/11/2004
How refreshing to buy a bit of kit that actually works better than you expected it too. Straightforward setup. Good set of features. Web interface easy to use. Wireless working well with excellent range. Very happy with it.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
NETGEAR DG834Gv5 - wireless router - DSL - 802.11b/g - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
IPSec VPN tunnels : 5
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, PPPoE, PPPoA
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
DMZ port, auto-sensing per device, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, E-mail alert, Wireless Distribution System (WDS) support, URL filtering, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), DHCP server, DNS proxy, Green Ethernet
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED
Environmental Standards
ENERGY STAR Qualified
17.5 cm x 11.9 cm x 2.8 cm
300 g
United Kingdom
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT) Annex A
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x ADSL2+ - RJ-11
Power adapter - external
17.5 cm
11.9 cm
2.8 cm
300 g
Vertical stand
1 x network cable , 1 x phone cable
United Kingdom
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
