The ProSAFE GBIC Module is a LC duplex connector and meets SFP GBIC standard for use with any SFP GBIC compliant slot.
Product Description | NETGEAR ProSafe AGM732F - SFP (mini-GBIC) transceiver module - 1GbE | Device Type | SFP (mini-GBIC) transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 1000Base-LX | Data Transfer Rate | 1 Gbps | Data Link Protocol | 1GbE | Max Transfer Distance | 10 km | Designed For | NETGEAR GSM7224, M4300-28G-PoE+ |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-LX - LC single-mode |
Compatible Slots | 1 x SFP (mini-GBIC) |
Compatibility Information | |
