NetGear 5-Port 10/100 Switch
Customer rating
View reviews
Hang on - your network will soar when it's hooked up to NETGEAR's FS605! This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network. You'll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS605's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
Write a review for the NetGear 5-Port 10/100 Switch here!
good switch. nice design.
has mount so you can mount it vertically.
only has data transfer lights (no duplex/full duplex) lights.
apart from that.. no complaints.
running 24/7 no probs for nearly a year.
Top quality switch. I've currently been running it 24/7 for over 6 months with absolutely no problems. Transferred over 20Tb with this switch as part of a 100Mbit campus network. Would strongly recommend.
Small and Sleek design, just sits on my desk flashing it's lights at me been using it for about a year now
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
