Meta's most premium headset. A whole new way to work, create and collaborate.
Work in the virtual world. Stay in the real world.
With breakthrough high resolution mixed reality, you can engage effortlessly with the virtual world while maintaining presence in your physical space in hi-def colour.
Product Description | Oculus Quest Pro - virtual reality system | Device Type | Virtual reality system | Features | Wi-Fi, Bluetooth 4.2 adapter | Sensors | Motion sensor, infrared eye tracking system | Resolution per Eye | 1800 x 1200 | Audio Input | Microphone | Dimensions (WxDxH) | 26.5 cm x 26.5 cm x 12.7 cm | Weight | 722 g |
General | |
Display Type | Virtual reality system |
Configuration | Qualcom Snapdragon XR2+, 12 GB RAM, 256 GB ROM |
Built-in Devices | Wi-Fi, Bluetooth 4.2 adapter |
Weight | 722 g |
VR Headset | |
Features | Adjustable headband, eye relief adjustment, full-colour mixed reality, 55-75 mm mechanical lens spacing |
Audio Input | |
Type | Microphone |
Audio | |
Type | Speakers - stereo |
Connectivity | |
Interfaces | Headphones (mini-jack) , USB-C |
Miscellaneous | |
Included Accessories | Cleaning cloth, protective cover, cable clip, USB-C power adapter, 2 Meta Quest Touch Pro controllers, charging dock, 2 stylus tips, 2 partial light blockers (left and right), 2 wrist straps, headset charging cable, controller charging cable |
Dimensions & Weight | |
Dimensions & Weight Details | Controller - width: 7 cm - depth: 6.2 cm - height: 13 cm - weight: 153 g |
