Take your headset and accessories on the go with style and protection. Designed to fit your headset, Touch Plus controllers, charging cable, adapter, head strap (standard or Elite) and Active Straps, this case features an outer felt shell and contoured inner compartments to keep your gear organised and secure. With its lightweight construction, soft hand strap, zip opening and rounded profile, the case makes it easy to carry and access your Meta Quest 3 and accessories on the go. This genuine Meta Quest accessory ensures a perfect fit, durability and convenience for your VR setup.
Product Description | Meta - case for virtual reality headset | Product Type | Case for virtual reality headset | Dimensions (WxDxH) | 24.18 cm x 32.83 cm x 12.8 cm | Weight | 674 g | Material | Felt | Colour | Light grey | Manufacturer Warranty | Limited lifetime warranty | Designed For | Meta Quest 3 |
General | |
Width | 24.18 cm |
Depth | 32.83 cm |
Height | 12.8 cm |
Weight | 674 g |
Material | Felt |
Carrying Case | |
Type | Case |
Recommended Use | For virtual reality headset |
Closure Type | Zipper |
Features | Lightweight |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
