BT.com
Wishlist
Luxor 32" HD LCD TV
Delivery
Standard Due date unavailable
This bargain priced 32in HD Ready LCD TV comes packed with features in a slimline LCD design, with integrated Freeview!
Just simply insert your USB device into the TV to playback your favourite movies, TV shows and photos.
An integrated Freeview tuner will allow you to watch all your favourite shows from over 80 TV and 20 radio stations across the country - without the need for an additional set-top box.
Two HDMI inputs ensure you'll have enough ports to allow you to connect a couple of AV sources to your TV such as home cinema systems, games consoles, blu-ray players, set-top boxes or laptops.
You can even use it as your PC monitor or attach your laptop to it. Just simply connect either a VGA or HDMI cable to your TV and you'll get to experience all your media via your TV.
A USB Input enables you to play music and photos directly from your USB drive. This really allows your TV to be the hub for all your home entertainment - making your own photos and music even more enjoyable to watch. You'll be right at the heart of the action. You'll be able to play DAT, WMA, MP3, JPEG and BMP files.
Its lightweight and slimline design ensures that you can easily move it from room to room and will create so much extra space when compared to older CRT models.
Widescreen Aspect Ratio. Digital TV tuner built-in, receive digital TV and radio, no additional box required. HD Ready. High resolution pixel density with built-in image scaler to handle inputs from a variety of digital and analogue audio/video source.
Main Features
Brand Luxor
Screen Type LCD
Screen Size 32"
Screen Resolution 720p HD Ready
Digital Tuner Freeview
Connections 2 X HDMI , 1 X VGA , 1 X USB
File Playback: .MPG, .MPEG, .DAT, .VOB, .AVI, .JPG, .JPEG, .BMP, .MP3, .WMA
Brightness 300
Aspect Ratio 16:09
Contrast Ratio 4000:1
Wallmount Size 200 x 200 VESA Std.
USB Support.
Headphone Socket
Standby Power Consumption - 0.5W
Header / Brand
Luxor
Television / Type
LCD TV
Diagonal Size (inches)
32 in
Television / Diagonal Size (cm)
81 cm
Aspect Ratio
16:9
TV Tuner / Digital TV Tuner
DVB-T
TV Tuner / Digital TV Service
FREEVIEW
HD Standard
720p
Television / Progressive Scan
Progressive scanning (line doubling)
Native Resolution
1,366 x 768
Television / HDMI Ports Qty
2
Composite, HDMI, USB, VGA, Component
Television / PC Interface
VGA (HD-15)
Video Input / Analogue video Signal
Scart
Tuner Type
1x digital
HDMI Inputs
2
TV Tuner / Tuner Qty
1
Memory Card Reader / USB Ports Qty
2
Audio System / Speaker System
2 speakers
Contrast Ratio
4000:1
Display / Response Time
6.5 ms
Dimensions & Weight / Width
788 mm
Dimensions & Weight / Height
567 mm
Dimensions & Weight / Weight
12.3 kg
Dimensions & Weight (Shipping) / Shipping Weight
13.5 kg
Dimensions & Weight / Depth
94 mm
Audio Output / Form Factor
Digital (Coaxial)
Network & Internet Multimedia / Functionality
Digital video playback
Television / Digital Television Certification
HD ready
Video Input / Digital Video Standard
High-Definition Multimedia Interface (HDMI)
TV Tuner / Conditional Access
Common Interface (CI) slot
Remote Control / Technology
Infrared
Audio Output / Speakers Configuration
Stereo
Network & Internet Multimedia / Connectivity Protocols
USB
CE System / Parental Lock
DVD / MP3 Playback
Stands & Mounts / Stand Included
Television / HDCP Compatible
Television / HDTV Ready
Television / Parental Channel Lock
TV Tuner / Teletext
Miscellaneous / Compliant Standards
RoHS
Scroll to top
