Click to visit BT.com
Logitech Z320 PC Multimedia Speaker System - 10 Watt
Logitech Logitech Z320 PC Multimedia Speaker System - 10 Watt
4 in stock
Quicklinx: 69XLWS00
Mfr#: 980-000330
£42.90
Speaker System Z320
A compact, two-speaker system that delivers rich, clear sound--to every corner of your room.
Your room isn't just a room. It's your office, your dance floor, your movie theater, your arcade. And because you don't just listen to music sitting at your desk, your Logitech Speaker System Z320 sends clear, vibrant sound evenly anywhere in the room. It is perfect for music, movies, and games.
360-degree sound
The speakers project sound evenly in all directions, so you enjoy rich, clear sound from any angle throughout the room.
Music isn't about staying still. It's about movement. Yet most speakers are designed to sound their best when you're sitting right in front of them.
But you don't have to just sit there and take it. You can choose speakers that sound good throughout the room--Logitech speakers with 360-degree sound.
With most speakers, you need to sit in the sweet spot - usually smack dab in the middle, depending on how you've arranged your system - to get the best sound. Dance around the room or pick a different seat and your audio just won't sound right.
That's because the high and mid frequencies drop out when you move to the side or back of the speaker. (Their shorter wavelengths don't wrap around the speaker like low frequencies.)
Our 360-degree speakers are different. They've got both forward- and backward-firing drivers that project sound more uniformly around the speaker over a wider range of frequencies--not just the low ones. That means the direct and reflected sound are more tonally balanced for a better, more immersive listening experience.
The result? A broad sweet spot that gives you rich, balanced sound in every corner of the room and everywhere in between. So, you can go ahead and make your move.
Two-speaker, stand-alone system
You get a full range of sound in a small package that's perfect for your notebook computer.
10 watts (RMS)
You can turn up the volume on your music, videos, and games.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Logitech Z320 PC Multimedia Speaker System - 10 Watt
Logitech Z 320 - PC multimedia speakers
8.9 cm x 8.9 cm x 19.8 cm
System Components
2 speakers
Speaker Type
Active
Nominal Output Power (Total)
10 Watt
Response Bandwidth
70 - 20000 Hz
Audio Amplifier
Integrated
Wired
Speaker System Details
2 x right/left channel speaker - 5 Watt - 70 - 20000 Hz
2 years warranty
8.9 cm
8.9 cm
19.8 cm
Speaker System
System Components
2 speakers
Speaker Type
Active
10 Watt
Response Bandwidth
70 - 20000 Hz
Audio Amplifier
Integrated
Wired
Controls
Volume
Speakers Included
2 x right/left channel speaker - 5 Watt - 70 - 20000 Hz - wired
Driver Details
Right/left channel speaker : 1 x full-range driver
Connector Type
1 x headphones ( mini-phone stereo 3.5 mm ) , 1 x audio line-in ( mini-phone stereo 3.5 mm )
Power adapter - external
2 years warranty
Service & Support Details
feature value
System Type PC multimedia speakers
Type 2 speakers
Power 10Watt
Brand Logitech
Stock Status In Stock
Price Range Inc VAT 0 - 50
