Logitech Z 5500 Digital - PC multimedia home theatre speaker system - 505 Watt (Total)
Customer rating
View reviews
Logitech has taken its award-winning Z-680 speaker system and made it even better. How? By improving everything from the subwoofer to the satellites and adding new innovations like real-time digital sound equalization.
The result is the Logitech Z-5500 Digital, a THX-certified, 505-watt 5.1 surround sound speaker system that offers everything you could possibly want... and some things you didn't even know you needed. And once you plug in your PC, DVD or music player, or video game console, you'll never want to listen to anything else.
Many call the Z-5500 Digital speakers the best multimedia system ever. 505-watt RMS and a deep note 25.4 cm (10") subwoofer deliver thundering power, THX-certified, high fidelity, theatre-quality sound. You can simultaneously connect up to 6 audio sources (PCs, video game consoles and DVD/CD/portable music players). Innovative satellite design with removable cloth grilles and rotating pedestals allow desk placement or wall-mounting, so you can transform any room into a home theatre.
Select any thumbnail below to view a larger image.
Write a review for the Logitech Z 5500 Digital - PC multimedia home theatre speaker system - 505 Watt (Total) here!
It's as simple as that, these are amazing. Not just for power, but all out quality. The clarity of the highs is so crisp and the rumble of the lows adds an amazing amount of depth, whether you're watching a movie, playing a video game on your PS3 or just listening to music.
TIP: Do NOT flip the switch to the OFF position on the back of the sub as this tends to blow the little 2A slow blow (or time delay) fuse that is installed. If you want to switch the system off completely, then do it directly at the mains. But FYI, you can pick up a pack of 10 2A time delay fuses from Maplin for around £2.50.
perfect..nice sound,great sistem...
Bought this product a couple of months ago so had some proper time to test it out. Firstly … the sub is big, and when I say big I mean it. Make sure u got place for it set out before u buy it. After u got it all set up u realise why it has been promised to be worth the while by so many other customer reviews. Logitech seem to favour bass over actual sound quality so if u planning to listen to classic music all day this might not be the thing for u, that doesn’t mean sound quality is bad of course, just means its comes well second to the bass. Surround sound is excellent and movies are brought to life by this system. The z – 5500 connects to almost any sound producing equipment (pc I pob, e-box est.) which makes this product even more worth the money. If u want entertainment this is the thing to go for.
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
