Click to visit BT.com
Logitech S-220 - 2.1-channel PC multimedia speaker system - 17 Watt (Total)
Logitech Logitech S-220 - 2.1-channel PC multimedia speaker system - 17 Watt (Total)
13 In stock
Quicklinx: 4L6MWS00
Mfr#: 980-000022
£22.93
Customer rating
5.0*
View reviews
Enjoy rich acoustics with a high-quality subwoofer (9 W) and two satellite speakers (4 W each). A high-performance, piano-finish control base adds convenient access to volume, power, and bass controls.
Headphone and microphone jacks are conveniently located on the wired remote.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Logitech S-220 - 2.1-channel PC multimedia speaker system - 17 Watt (Total)
Customer reviews read all 1 customer reviews
Write a review for the Logitech S-220 - 2.1-channel PC multimedia speaker system - 17 Watt (Total) here!
Genuinely Good
Reviewed by elaine callaghan. Review Posted 20/04/2011
really easy to set up and gives good sound quality. volume control could be a bit better developed but it really does not cause a problem. if i can use it then anyone can! Prompt delivery.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Logitech S-220 - PC multimedia speaker system
United Kingdom
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
17 Watt
Audio System Max Output Power
34 Watt
Audio Amplifier
Integrated
Wired
Speaker System Details
2 x satellite speaker - 4 Watt , 1 x subwoofer - 9 Watt
Remote Control
Remote control - cable
AC 240 V
3 years warranty
Design Features
Piano finish
United Kingdom
Speaker System
System Components
Speaker Type
Active
17 Watt
Max (RMS) Output Power (Total)
34 Watt
Audio Amplifier
Integrated
Wired
Controls
Power on/off, volume, bass
Speakers Included
2 x satellite speaker - 4 Watt - wired , 1 x subwoofer - 9 Watt - wired
Connector Type
1 x headphones ( mini-phone stereo 3.5 mm ) , 1 x microphone ( mini-phone 3.5mm )
Packaging Type
OEM
Audio cable kit
Remote Control
AC 240 V
3 years warranty
Service & Support Details
Limited warranty - 3 years
feature value
System Type PC multimedia speaker system
Type 2 speakers
Type Subwoofer
Power 17Watt
Brand Logitech
Stock Status In Stock
Price Range Inc VAT 0 - 50
