Click to visit BT.com
Logitech Harmony Adapter for PS3
Logitech Logitech Harmony Adapter for PS3
Usually dispatched within 3 working days
Quicklinx: 62TZWS00
Mfr#: 943-000030
£40.80
Harmony® Adapter for PLAYSTATION®3
Your Harmony remote already controls the most important pieces of your home-entertainment environment with one notable exception - your PLAYSTATION 3. The Logitech Harmony Adapter for PLAYSTATION 3 works with your Harmony remote, so you get a single remote that controls your entire home entertainment system.
  • Works with Logitech Harmony remotesNo compatibility worries. Your PLAYSTATION 3 Adapter is designed to work with your Logitech Harmony remote.
  • Supports all 51 PLAYSTATION 3 commandsSupports all 51 PLAYSTATION 3 commands: control your DVD and Blu-Ray Disc movies, navigate the XrossMediaBar (XMB) and even power your PLAYSTATION 3 on and off without using your game controller.
  • Compact, low-profile designNo extra clutter. The adapter blends discreetly into your home-entertainment environment.
  • Guided online setupYou connect your Harmony remote to your computer and you're guided through every step. If you hit a snag, customer support is ready to help.
  • Always on, wireless linkThis adapter uses AC power and a Bluetooth wireless connection to communicate with your PLAYSTATION 3. So, your remote works whether your console is on or off. And your valuable USB ports remain available for more other controllers.
Logitech Harmony Adapter for PLAYSTATION 3 - remote control adapter
Remote control adapter
Sony PlayStation 3
Sony PlayStation 3
feature value
Brand Logitech
Price Range Inc VAT 0 - 50
