Click to visit BT.com
Logitech Harmony 300i Universal Remote Control
Logitech Logitech Harmony 300i Universal Remote Control
Usually dispatched within 3 working days
Quicklinx: 6ZS3WS00
Mfr#: 915-000153
£26.98
Harmony® 300i Remote
Logitech Harmony 300i is the remote that's simple to set up, easy enough for anyone to use and gives you better control of what's attached to your TV. Online setup makes it easy to programme. And we support 5000+ brands, so you'll have the control you need - today and tomorrow. There's a Watch TV button that turns on your TV and cable/satellite box with just one button press, as well as a set of programmable buttons that you can use to jump right to your favourite channels or use for custom control. Harmony 300i makes digging out another remote to change inputs, switch screen sizes or control your DVR a thing of the past.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Logitech Harmony 300i Universal Remote Control
Logitech Harmony 300i - universal remote control
Universal remote control
Supported Devices
DVR, TV, sattelite TV system
Input Device
Keypad
2 x standard - AA type
2 years warranty
Remote Control
Supported Devices
Input Device
Keypad
Programmable
Connector Type
1 x USB
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.8 or later
1 x USB cable - external
Included Qty
2
2 years warranty
Service & Support Details
feature value
Type Remote Control
Brand Logitech
Price Range Inc VAT 0 - 50
