Click to visit BT.com
Logitech G13 Advanced Gameboard - Command Pad PC & MAC
Logitech Logitech G13 Advanced Gameboard - Command Pad PC & MAC
1 in stock
Quicklinx: 5DWJWS00
Mfr#: 920-000947
£71.91
You can dig in, take command, and stay informed with game-changing comfort and control. Or an LCD gameboard that gives you game-changing comfort and control--wherever you go.
High-visibility GamePanel™ LCD
You've got easy access to tactical information, including live stats, system info, and communications from your fellow players.
Built in to several of our gaming keyboards and gameboards, GamePanel allows you to keep an eye on real-time information such as player rank, server IP, score, times, health status, and ammunition levels in over 35 supported games.
GamePanel can also help you check to make sure your system is performing up to speed, and can even provide media/music information, deliver e-mail notifications, plus lots more.
25 programmable keys
You can customize keys to suit your style of play--and even assign complex actions to single keystrokes on the fly
Backlit keys
You can customize the keys with any backlight color that you want. Easily locate the right key in low-light conditions or lights-out play.
Programmable mini-joystick
The control you need is under your thumb so you can maneuver quickly and easily.
Public software development kit (SDK)
You can upload the latest enhancements developed exclusively for GamePanel™ by the Logitech open-source community.
Naturally contoured design
It follows the natural shape of your hand and fingers for increased comfort during long sessions.
Large, concave buttons
You can locate buttons by touch on the home row.
Solid, stable design
Your gameboard will keep up when your game gets intense. Strategically placed feet. Stable weight (650 grams).
Onboard memory
It saves your profiles so you can take your personal preferences with you.
Portable design
This portable gameboard keeps the game going wherever you go.
Image gallery
Select any thumbnail below to view a larger image.
  • Naturally contoured designFollows the natural shape of your hand and fingers for increased comfort during long sessions.
  • Large, concave buttonsLet you locate buttons by touch on the home row.
  • Solid, stable designHelps assure that your gameboard will keep up when your game gets intense.
  • Twenty-five programmable keysCustomize keys to suit your style of play.
  • Quick macrosAssign complex actions to single keystrokes - on the fly.
  • Programmable mini-joystickManeuver quickly and easily. The control you need is under your thumb.
  • Backlit keysLet you easily locate the right key in low-light conditions or lights-out play. Plus, you can customize the keys with any backlight color that you want.
  • Onboard memorySaves your profiles so you can take your personal preferences with you.
  • Portable designKeeps the game going wherever you go.
  • High-visibility GamePanel LCDGather tactical information, including live stats, system info, and communications from fellow players.
Logitech G13 Advanced Gameboard - command pad - wired
Command pad
Wired
Buttons Qty
25
Controls
Joystick
LCD screen, backlighting
Microsoft Certification
Compatible with Windows 7
2 years warranty
Command pad
Wired
Buttons Qty
25
Controls
Joystick
1 x USB - 4 PIN USB Type A
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Software Included
Drivers & Utilities
0.7 kg
2 years warranty
Service & Support Details
feature value
Type Command pad
Wired / Wireless Wired
Compatibility PC
Brand Logitech
Stock Status In Stock
Price Range Inc VAT 50 - 100
