Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Linksys E4200 Maximum Performance Dual-Band Wireless-N Router
Quicklinx: 7FKLWS00
Mfr#: E4200-UK
Standard delivery Delivered within 3 working days from date of dispatch
Essential accessories
Built with leading 802.11n wireless technology, the Linksys E4200 offers maximum speed and range to create an ultra-powerful network designed for home theater performance. Connect your computers, Internet-ready TVs, game consoles, and other Wi-Fi devices at transfer rates up to 300 + 450 Mbps for an unrivaled experience.
Double your network bandwidth with simultaneous dual-band N (2.4 and 5 GHz) designed to avoid interference and optimize throughput for smoother and faster HD video streaming, file transfers, and wireless gaming. The USB storage port lets you add an external USB drive to your network and share files at home or over the Internet. Plus, a built-in UPnP AV Media Server for seamless streaming of your video and media files to an Xbox 360, PS3, or other UPnP compatible device. Bring the ultimate entertainment experience to your home by connecting computers, Internet-ready TVs, game consoles, media players and more to your wireless network and the Internet. Simultaneous dual-band N and QoS traffic prioritization technology delivers maximum speed and performance so you can enjoy fast downloads, smooth video and music streaming, and lag free gaming and VoIP.
Linksys E4200 - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP, HTTPS
Firewall protection, 128-bit encryption, DMZ port, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, parental control, firmware upgradable, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, UPnP Media Server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
22.5 cm x 16 cm x 2.5 cm
355 g
Microsoft Certification
Compatible with Windows 7
Microsoft Windows 7, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows XP SP3, Microsoft Windows Vista SP1 or later
1 year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz, 5 GHz
Routing Protocol
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP , IC, FCC
Line Properties
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0 : 1 x 4 PIN USB Type A , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
Internal integrated
Antenna Qty
6
External power adapter
1 x network cable
Software Included
Drivers & Utilities
22.5 cm
16 cm
2.5 cm
355 g
1 year warranty
Service & Support Details
Limited warranty - 1 year
10 - 80% (non-condensing)
