Click to visit BT.com
Linksys By Cisco Wireless-N Home BT ADSL2+ Modem Router
Linksys By Cisco Linksys By Cisco Wireless-N Home BT ADSL2+ Modem Router
Usually dispatched within 3 working days
Quicklinx: 6L49WS00
Mfr#: WAG120N-UK
£51.16 inc VAT
Enjoy fast wireless connectivity for your home or office. The Wireless-N Home ADSL2+ Modem Router has a built-in high-speed ADSL2+ modem for a fast, "Always On" connection to the Internet. Wireless connections use Wireless-N technology for fast data transfers, and the four built-in 10/100 Ethernet ports supply high-speed connections to your wired devices.
Step up to the speed of Wireless-N
Easily create an around-the-home wireless network experience. Wireless-N technology allows your whole family to share one broadband Internet connection. Great for wireless printing and sharing files. Get best results when connecting to other Wireless-N devices, but also works great with Wireless-G and -B equipment.
Connection Versatility
Keep your digital files in one place, and share them from any computer on your network. Four built-in 10/100 Ethernet ports make it easy to connect additional wired computers, storage, printers, and other wired devices to your network.
Advanced Security
Advanced wireless security and SPI firewall protection helps safeguard your home network and computers from most Internet attacks.
Image gallery
Select any thumbnail below to view a larger image.
  • Wireless speed and rangeThe Wireless-N Home ADSL2+ Modem-Router uses the very latest wireless networking technology, Wireless-N. By overlaying the signals of multiple radios, Wireless-N's "Multiple In, Multiple Out" (MIMO) technology multiplies the effective data rate.
  • Fast wired connectionsThe modem-router also provides connections for 4 directly-wired network devices. You'll get fast file transfers to network storage devices, printers, and other wired network devices.
  • On-time delivery with QoSAnd, to deliver your time-sensitive Internet traffic efficiently, the modem-router features Quality of Service (QoS) capabilities. QoS tells your network to give priority to packets in time-sensitive streams like Voice (VoIP) or media (audio or video), so that these types of applications can deliver less garbled conversations and smoother digital video.
  • Wireless securityTo help protect your data and privacy, the modem-router can encrypt all wireless transmissions with the latest industrial-strength 128-bit encryption.
  • Internet securityThe Wireless-N Home ADSL2+ Modem-Router has a powerful SPI firewall to help protect you against intruders and most known Internet attacks. The modem-router also features filter that lets you deny specific types of Internet requests, and block certain application types.
  • Access controls for parentsOf growing concern for parents is the amount and type of Internet access their families have. The Wireless-N Home ADSL2+ Modem-Router can help. Parents can create policies for each PC in the house, to control access by time and day, specific website, keyword, protocols, or applications.
  • The heart of your home networkWith the Linksys Wireless-N Home ADSL2+ Modem-Router at the center of your home network, you can connect to a high-speed Internet connection, share web access, files, printers, and multi-player games, and run media-intensive applications, both wired and wirelessly!
Linksys Wireless-N Home ADSL2+ Modem Router WAG120N - wireless router - DSL - 802.11b/g/n (draft 2.0) - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
128-bit encryption, DMZ port, DHCP support, NAT support, 64-bit encryption, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IP address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup, IEEE 802.11n (draft 2.0)
DC 12 V
20.2 cm x 16 cm x 3.4 cm
362 g
Microsoft Certification
Compatible with Windows 7
Apple MacOS X 10.4 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Vista / XP
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Status Indicators
Port status, link activity, power
Line Properties
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.5 Annex A
WAN : 1 x ADSL2+ - RJ-11 , LAN : 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
Internal integrated
Antenna Qty
2
Gain Level
1.8 dBi
Power adapter - external
DC 12 V
20.2 cm
16 cm
3.4 cm
362 g
1 x network cable
CE, UL, CB, FCC
United Kingdom
Software Included
Drivers & Utilities
Peripheral / Interface Devices
CD-ROM
10 - 85%
Accessories
1-1 products displayed out of 1
  product description   In stock inc VAT qty
  Linksys By Cisco Wireless-N PCI Adapter with Dual-Band Linksys By Cisco Wireless-N PCI Adapter with Dual-Band
quicklinx: 5KPRWS00 | Mfr#: WMP600N-EU
In stock £36.90
feature value
Type Wireless router
Connection Type ADSL (BT)
Standards Ethernet
Standards Fast Ethernet
Standards IEEE 802.11b
Standards IEEE 802.11g
Standards IEEE 802.11n (draft 2.0)
Rackmount or External External
Brand Linksys By Cisco
Price Range Inc VAT 50 - 100
