Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Lexar Jumpdrive S73 - USB Flash Drive - 128GB - USB 3.0
Quicklinx: 8PWCWS00
Mfr#: LJDS73-128ABEU
£49.99
Essential accessories
Faster File Transfer with USB 3.0 Technology
The affordable, high-performance Lexar® JumpDrive® S73 USB 3.0 flash drive allows you to quickly transfer photos, videos, and files. The drive features a retractable connector with an easy-to-use thumb slide, comes in a range of colors, and is available in capacities from 8GB-128GB.
  • Stores and transfers content faster with SuperSpeed USB 3.0 technology
  • Speeds up to 4x faster than standard JumpDrive® USB 2.0 drives
  • Retractable connector with convenient thumb slide
  • Reliably stores and transfers photos, videos, files, and more
  • Compatible with PC and Mac® systems
  • Three-year limited warranty
Convenient, Reliable Portable Storage
Store and Transfer Content Faster. With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. The 8GB-64GB capacities deliver speeds up to 3x faster (up to 45MB/s read and 20MB/s write) than standard JumpDrive USB 2.0 drives.(1) You can quickly transfer a 3GB HD movie clip in less than 90 seconds, compared to the 20 minutes it takes using a standard USB 2.0 drive.(3) And for added versatility, JumpDrive S73 is backwards compatible with USB 2.0 devices.
High-capacity 128GB option.
The 128GB option of the JumpDrive S73 drive comes with added speed benefits, allowing you to transfer files up to 4x faster(2) (up to 100MB/s read and 55MB/s write) than standard JumpDrive USB 2.0 drives. This means you'll not only store much more of your favorite content, but you'll be able to transfer those files at impressive speeds.
Designed for Convenience.
Beyond its performance and good looks, JumpDrive S73 is designed for convenience. It sports a retractable connector with easy-to-use thumb slide, and also includes a key ring loop so you can easily attach it to your keychain, computer bag, backpack, or purse.
Colorful Style.
Lexar JumpDrive S73 comes in a range of colorful capacity options--8GB in blue, 16GB in purple, 32GB in orange, 64GB in green, and 128GB in black. These stylish options make it fun and easy to find one to suit your needs and reflect your personality. They also provide you with a built-in color coding system to help you organize your drives and their contents.
Lexar Performance, Quality, Compatibility, and Reliability
All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Lexar offers a comprehensive line of innovative, award-winning memory products in several categories, including memory cards, card readers, and USB flash drives. With so many options, it's easy to find the right Lexar solution to fit your needs.
Lexar. When Memory Matters.™
(1)Based on 8GB-64GB capacities. Up to 3x faster write, 2x faster read speeds when compared to standard JumpDrive USB 2.0 drives using a USB 3.0 port. Speeds based on internal testing. Actual performance may vary.
(2)Based on 128GB capacity. Up to 4x faster read and write speeds when compared to standard JumpDrive USB 2.0 drives using a USB 3.0 port. Speeds based on internal testing. Actual performance may vary.
(3)Based on 8GB-64GB capacities. 3.3GB video, HD 1080p@30fps (46 Mbps) video.
Lexar JumpDrive S73 - USB flash drive - 128 GB
USB flash drive
Storage Capacity
128 GB
Interface Type
USB 3.0
Enclosure Colour
USB flash drive
Storage Capacity
128 GB
Enclosure Colour
Compatibility
Non-specific
Read Rate
Up to 100 MB/s
Write Rate
Up to 55 MB/s
Interface Type
USB 3.0
