Your business needs fast and secure professional network storage. It should let you back up multiple workstations and quickly share files, regardless of client operating system. Enter the LaCie 2big NAS: a complete backup solution that's easy to set up and with full security.
Product Description | LaCie 2big - NAS server | Device Type | NAS server | Host Connectivity | USB 2.0 / Gigabit Ethernet | Installed Devices / Modules Qty | 0 (installed) / 2 (max) | Weight | ) | Processor | 2 GHz | Storage Controller | 1 x RAID RAID RAID 0, 1 | Hard Drive | Apple Time Machine compatible | Networking | Network adapter 10Mb LAN, 100Mb LAN, GigE | RAM | 256 MB | Storage Operating System | LaCie NAS OS 2 | System Requirements | Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5, Apple MacOS X Lion 10.7 | Manufacturer Warranty | 3-year warranty |
General | |
Total Storage Capacity | 0 GB |
Weight | ) |
Processor / Memory | |
Processors Installed | 2 GHz |
RAM | 256 MB |
Storage Controller | |
Type | 1 x RAID |
Max Storage Devices Qty | 2 |
RAID Level | RAID 0, RAID 1 |
Hard Drive | |
Type | HDD - hot-swap |
Features | Apple Time Machine compatible |
Networking | |
Type | Network adapter |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | NTP, iSCSI, FTP, DHCP, SMB |
Remote Management Protocol | HTTP, HTTPS |
Network Services Compatibility | Apple Bonjour Protocol, Apple File Protocol (AFP), APIPA |
Features | Wake on LAN (WOL), print server, iTunes server, BitTorrent Client, UPnP Media Server |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x hot-swap |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x eSATA |
Miscellaneous | |
Cables Included | 1 x network cable |
Included Accessories | Vertical stand |
Power | |
Power Device | External power adapter |
Software / System Requirements | |
Software Included | LaCie Network Assistant |
OS Required | Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5, Apple MacOS X Lion 10.7 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
