With the LaCie Network Space 2, you're not simply storing files from your computer; you're storing files from all over your home. Connect the Network Space 2 through the Ethernet port to a computer or to a router, and share and store all of your media files from anywhere in your house, with the read and write speeds that you need. You can even back up multiple computers to ensure that your files are safe. The included LaCie Network Assistant allows you to quickly start using your product after completing a few short steps. This helps the Network Space 2 to be user-friendly and incredibly easy to use - just like a classic LaCie hard disk. It's easy to access the LaCie Network Space 2 from any computer connected on the local network or any networked equipment that's UPnP®/DLNA® certified (like your PlayStation®3 or Xbox®). At home, networked computers can access the iTunes library or stored photos and everyone can stream music or videos to a networked UPnP AV-certified player or adapter. The Network Space 2 even comes with built-in private and public shares. The remote access feature means that your files are always accessible, even if you aren't around. You can even access your torrent downloads, or automatically import pictures when your computer is switched off! Mac Compatible: Mac® OS X 10.5, 10.6 |
