Click to visit BT.com
Kingston Media Reader - 19-in-1 Card Reader - Hi-Speed USB
Kingston Kingston Media Reader - 19-in-1 Card Reader - Hi-Speed USB
14 In stock
Quicklinx: 5K9TWS00
Mfr#: FCR-HS219/1
£8.98
Nothing goes better with digital media than an external reader for your desktop or laptop at home or on the road. Kingston's Media Reader opens a direct gateway between your digital media and a USB port by simply using expandable storage cards to move photos, music, data and more between devices and eliminating the need to carry cables to connect multiple devices.
  • Dimensions -- 3.61" x 2.71 x 0.79" (91.72mm x 68.82mm x 20.06mm)
  • Speed Rating* -- USB 2.0, up to 480 Mbps data transfer speed
  • Operating Temperature -- 32° to 140° F / 0° to 60° C
  • Storage Temperature -- -4° to 185° F / -20° to- 85° C
  • Weight -- 0.1585 lbs (71g)
  • Operating System Compatibility -- Windows® 7, Windows Vista®Windows Vista (SP1, SP2), Windows XP (SP1, SP2, SP3), Windows 2000 (SP4), Mac OS (v. 10.3.x +)
Kingston Media Reader - card reader - Hi-Speed USB
Card reader ( external ) - Hi-Speed USB
Card Reader Type
19 in 1 card reader
Supported Flash Memory
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, MultiMediaCardmobile, microSD, MultiMediaCardplus, MultiMediaCardmicro, SDHC Memory Card, miniSDHC, Memory Stick Micro (M2), microSDHC
Microsoft Windows 2000 SP3 or later, Microsoft Windows XP SP1 or later, Apple MacOS X 10.x or later, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
2 years warranty
Card Reader Type
19 in 1 card reader
91.7 mm
68.8 mm
20.1 mm
71 g
1 x Hi-Speed USB - 4 PIN USB Type A
USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Plug and Play
2 years warranty
Service & Support Details
feature value
Supported Formats CompactFlash Card type I
Supported Formats CompactFlash Card type II
Supported Formats Memory Stick
Supported Formats Memory Stick Duo
Supported Formats Memory Stick Micro (M2)
Supported Formats Memory Stick PRO
Supported Formats Memory Stick PRO Duo
Supported Formats Microdrive
Supported Formats microSD
Supported Formats microSDHC
Supported Formats miniSD
Supported Formats miniSDHC
Supported Formats MultiMediaCard
Supported Formats MultiMediaCardmicro
Supported Formats MultiMediaCardmobile
Supported Formats MultiMediaCardplus
Supported Formats RS-MMC
Supported Formats SD Memory Card
Supported Formats SDHC Memory Card
Interface Hi-Speed USB
Brand Kingston
Stock Status In Stock
Price Range Inc VAT 0 - 50
