Click to visit BT.com
Kingston HyperX 4GB (2 x 2GB) DDR2 1066MHz / PC2-8500 CL5 DIMM 240-Pin
Kingston Kingston HyperX 4GB (2 x 2GB) DDR2 1066MHz / PC2-8500 CL5 DIMM 240-Pin
4 in stock
Quicklinx: 5GZQWS00
Mfr#: KHX8500D2K2/4G
£49.99 inc VAT
Kingston, the world's largest independent memory leader, proudly offers HyperX, memory for gamers and PC enthusiasts. HyperX modules are specifically engineered and tested for higher speeds and lower latencies. HyperX is available in DDR and DDR2 memory technologies. Like all Kingston memory modules, HyperX is 100% tested, with a lifetime warranty and 24/7 free technical support.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Kingston HyperX 4GB (2 x 2GB) DDR2 1066MHz / PC2-8500 CL5 DIMM 240-Pin
Kingston HyperX memory - 4 GB : 2 x 2 GB - DIMM 240-pin - DDR2
Storage Capacity
4 GB : 2 x 2 GB
Upgrade Type
Generic
DDR2 SDRAM
DIMM 240-pin
Memory Speed
1066 MHz ( PC2-8500 )
Data Integrity Check
Non-ECC
Latency Timings
CL5 ( 5-5-5-15 )
Heat sink, dual channel , unbuffered
Supply Voltage
2.2 V
Lead Plating
Gold
Limited lifetime warranty ( Germany, Austria and France - 10 years )
Storage Capacity
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Memory Speed
Latency Timings
CL5 ( 5-5-5-15 )
Non-ECC
RAM Features
Module Configuration
256 x 64
Chips Organization
128 x 8
Supply Voltage
2.2 V
Lead Plating
Gold
Compatible Slots
2 x memory - DIMM 240-pin
feature value
Capacity 4GB
Connection DIMM 240-pin
Speed 1066MHz
Data Integrity Non-ECC
Registered/Buffered Unbuffered
CAS Latency CL5
Standard PC2-8500
Brand Kingston
Stock Status In Stock
Price Range Inc VAT 0 - 50
