Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Kingston 4GB 1333MHz SODIMM DDR3 204pin
Quicklinx: 7247WS00
Mfr#: KTH-X3B/4G
Marketing description is not available.
Kingston - DDR3 - 4 GB - SO DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3 SDRAM - SO DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9
Unbuffered
HP AT913AA, HP 575480-001, HP 577606-001, HP AT913UT, HP VH641AA, HP 599092-001, HP AT913ET, HP 599092-002
HP 100, 200, 3115, 42X, 45X, 60XX, 62X, 63X, 8200, Elite 8000; EliteBook 2170, 25XX, 27XX, 84XX, 85XX, 87XX; Envy 13, 14, 15, 17, DV6, DV7; Mobile Thin Client 4320; Pavilion dv6, dv7; Pro All-in-One 3420; ProBook 43XX, 44XX, 45XX, 47XX, 53XX, 6360, 64XX, 65XX; TouchSmart 9100, 9300, Elite 7320
4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
SO DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO DIMM 204-pin
HP EliteBook 2760p , HP Envy dv6-7200ea, dv6-7200sa, dv6-7201eg, dv6-7202eg, dv6-7202ss, dv6-7203es, DV6-7210US, dv6-7214nr, dv6-7214tx, dv6-7215nr, DV6-7220US, dv6-7222nr, dv6-7223nr, DV6-7227NR, dv6-7227sa, DV6-7228NR, dv6-7229nr, dv6-7240sg, dv6-7250ca, dv6-7251eo, dv6-7252eo, dv6-7254eo, dv6-7267cl, dv6-7276ez, dv6-7280la, dv6-7280sf, dv6-7290sf, dv6-7300ea, dv6-7300sa, dv6-7302eo, dv6-7370sf, dv7-7201eg, dv7-7202eg, dv7-7202ss, dv7-7203ea, dv7-7205tx, dv7-7212nr, dv7-7215sg, DV7-7230US, DV7-7240US, DV7-7243NR, DV7-7250US, dv7-7252eo, DV7-7259NR, dv7-7270ca, dv7-7290eb, dv7-7292eo, dv7-7299ef, dv7-7299sf , HP Pavilion dv6-2137el, dv6-3008et, dv6-3025et, dv6-3035et, dv6-3101et, dv6-3102et, dv6-3104et, dv6-3105et, dv6-3107et, dv6-3112st, dv6-3113et, dv6-3120et, dv6-3320et, dv6-3340et, dv6-6186nr, dv6-6b31eo, dv6-6b48nr, dv6-6c11sz, dv6-6c82sl, dv6-7000sy, dv6-7001em, dv6-7002ed, dv6-7003sm, dv6-7003sp, dv6-7009ss, dv6-7013cl, dv6-7014nr, dv6-7030sz, dv6-7041tx, dv6-7050ez, dv6-7050sw, dv6-7053ea, dv6-7054sa, dv6-7063sa, dv6-7070sw, dv6-7086la, dv6-7114nr, dv6-7115nr, dv7-2204tx, dv7-2206tx, dv7-2210eg, dv7-2215eb, dv7-2215eg, dv7-2215el, dv7-2215sa, dv7-2215sf, dv7-2220ec, dv7-2220ef, dv7-2220eg, dv7-2220en, dv7-2220ep, dv7-2225sf, dv7-2225ss, dv7-2230en, dv7-2230es, dv7-2232es, dv7-2235eb, dv7-2235es, dv7-2240ef, dv7-2270us, dv7-2273cl, dv7-2275eo, dv7-2277cl, dv7-3000, dv7-3004eb, dv7-3004TX, dv7-3005eg, dv7-3005ew, dv7-3006tx, dv7-3007sg, dv7-3007TX, dv7-3008TX, dv7-3010en, dv7-3010ew, dv7-3010so, dv7-3011eo, dv7-3012eo, dv7-3013eo, dv7-3014eo, dv7-3015eg, dv7-3015ew, dv7-3015sf, dv7-3017so, dv7-3020ea, dv7-3020eg, dv7-3020el, dv7-3020en, dv7-3020es, dv7-3020ew, dv7-3021eo, dv7-3025ss, dv7-3030eg, dv7-3030ew, dv7-3050ec, dv7-3060ca, dv7-3060eo, dv7-3060sb, dv7-3061nr, dv7-3063cl, dv7-3065dx, dv7-3067cl, dv7-3067nr, dv7-3080ca, dv7-3080us, dv7-3085dx, dv7-3090eo, dv7-3090ep, dv7-3169wm, dv7-4069wm, dv7-4197cl
