Click to visit BT.com
Kingston 4GB 1333MHz ECC Module
Kingston Kingston 4GB 1333MHz ECC Module
2 in stock
Quicklinx: 6DHLWS00
Mfr#: KTH-PL313E/4G
£31.40
All Kingston memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
Kingston memory - 4 GB - DIMM 240-pin - DDR3
Storage Capacity
4 GB
Upgrade Type
System specific
HP NL797AA
DDR3 SDRAM
DIMM 240-pin
Memory Speed
1333 MHz ( PC3-10600 )
Data Integrity Check
ECC
Unbuffered
HP ProLiant BL280c G6, BL460c G6, DL160 G6, DL170h G6, DL180 G6, DL320 G6, DL360 G6, DL360 G6 Efficiency, DL360 G6 Entry, DL370 G6, DL380 G6, DL380 G6 High Efficiency, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML350 G6, ML370 G6; Workstation z400, z600
Storage Capacity
4 GB
Upgrade Type
System specific
HP NL797AA
DRAM
DDR3 SDRAM
DIMM 240-pin
Memory Speed
ECC
RAM Features
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HP ProLiant BL280c G6, BL460c G6, DL160 G6, DL170h G6, DL180 G6, DL320 G6, DL360 G6, DL360 G6 Efficiency, DL360 G6 Entry, DL370 G6, DL380 G6, DL380 G6 High Efficiency, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML330 G6, ML350 G6, ML370 G6 , HP Workstation z400, z600
feature value
Type DDR3 SDRAM
Capacity 4GB
Connection DIMM 240-pin
Speed 1333MHz
Registered/Buffered Unbuffered
Brand Kingston
Stock Status In Stock
Price Range Inc VAT 0 - 50
