Get more life out of your computer and maximize your existing investment by replacing your old hard drive with a Kingston SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system - and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI SandForce controller customized for Kingston and optimized for flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
Compressible Data Transfer (ATTO)
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
IOMETER Maximum Random 4k Read/Write
PCMARK® Vantage HDD Suite Score
Product Description | Kingston SSDNow V300 Desktop/Notebook Upgrade Kit - solid state drive - 120 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 120 GB | Form Factor | 2.5" (in 3.5" carrier) | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | Shock resistant, TRIM support, SandForce Driven, S.M.A.R.T. | Dimensions (WxDxH) | 69.8 mm x 100.1 mm x 7 mm | Weight | 86 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 120 GB |
Form Factor | 2.5" |
Width | 69.8 mm |
Depth | 100.1 mm |
Height | 7 mm |
Weight | 86 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 450 MBps (read) / 450 MBps (write) |
Maximum 4KB Random Write | 55000 IOPS |
Reliability | |
MTBF | 1,000,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" or 3.5" (with included bay adapter) |
Power | |
Power Consumption | 2.052 Watt (active) , 0.64 Watt (idle) |
Software & System Requirements | |
Software Included | Drivers & Utilities |
Miscellaneous | |
Included Accessories | 3.5-inch bay adapter, 2.5" USB enclosure, 2.5mm mounting spacer |
Cables Included | 1 x Serial ATA cable - internal , 1 x Serial ATA power adapter - internal |
Mounting Kit | Included |
Compliant Standards | ISO 9001:2008 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Technical support |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Vibration Tolerance | 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating) |
