Click to visit BT.com
Iiyama Pro Lite T2250MTS-1 22" Widescreen 1920 x 1080 5MS DVI-D VGA LCD Monitor with Speakers
Iiyama Iiyama Pro Lite T2250MTS-1 22" Widescreen 1920 x 1080 5MS DVI-D VGA LCD Monitor with Speakers
10 In stock
Quicklinx: 6JJPWS00
Mfr#: PLT2250MTS-B
£273.14
The ProLite T2250MTS 22" Touch Screen is an early adoptor of the new 'MultiTouch' Technology. Based on the latest Optical Dual Camera sensor, the T2250MTS is Windows 7 Certified and ready for the emerging business and consumer software packages. The panel, ofcourse features High Definition 1920 x 1080 resolution with a 5msec response time. Analogue and DVI inputs are available for flexible connectivity along with USB for the Touch Interface.
Highlights of the IIyama T2250MTS-1 22" monitor
Screen: 22" FULL HD (1920 x 1080)
Brightness: 270 cd/m2
Contrast Ratio: 1000:1
Response time: 5ms
Connectivity: D-sub, DVI and USB
Integrated multimedia speakers
Multitouch Technology
Image gallery
Select any thumbnail below to view a larger image.
  • Full HDThis monitor can provide image resolution of 1920 x 1080 pixels.
  • VESA mountingThis device can be installed with the use of holders, which comply with the VESA standard. Thanks to this functionality, with the help of proper handles, the device can be mounted on a wall, a ceiling or other surface.
  • sRGB systemThis device is equipped with a possibility of regulation of the space of colors in the sRGB system. sRGB is a standard for HTML and CSS (Cascading Style Sheets).
Iiyama ProLite Touch T2250MTS-1 - LCD monitor - 22"
LCD monitor - 22"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.248 mm
Brightness
260 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
51.3 cm x 26.3 cm x 41.9 cm
6 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV, VCCI, DDC-2B
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
Stereo speakers
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Pixel Pitch
0.248 mm
Brightness
260 cd/m2
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
82 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+85 / -75
Controls & Adjustments
Volume, brightness, contrast, H/V position
HDCP
6 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x VGA cable , 1 x audio cable , 1 x USB cable
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
44 Watt
Power Consumption Stand by / Sleep
1 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
35 °C
10 - 80%
feature value
Diagonal Size 22in
Max Resolution 1920 x 1080
Response Time 5ms
Speakers Speaker(s)
Interfaces DVI
Interfaces VGA (HD-15)
Colour Black
Brand Iiyama
Stock Status In Stock
Price Range Inc VAT 150 - 300
