Huawei E5776 4G Mobile WiFi
-Compact and lightweight with LED screen
-Connects up to ten users
-Category 4 4G with up to 150Mbps download (subject to network)
-All mainstream UK 3G/4G networks pre-programmed
-Supports five second fast boot
-Ten hours working hours / 500 hours standby
-Memory stick function - files shareable with other connected users
-Battery charging pack function - including Micro USB lead
-2x2 WiFi antenna built in for enhanced coverage
-Smartphone control with Huawei Mobile WiFi App
With the pocket sized Huawei E5776 LTE Mobile WiFi, you can connect up to ten WiFi gadgets at a time at the touch of a button by creating your own personal Mobile WiFi hotspot. Share your lightening fast LTE Internet connection with friends, family or workmates allowing them to use WiFi enabled electronic gadgets such as tablets, laptops and gaming consoles at the touch of a button. The E5776's LED screen displays battery consumption, network signal and mail alerts. It also provides a memory stick function to share your files with other connected users. The E5776 is available in black. Easy to use, the Huawei Mobile Control App has been published in the Apple App Store and on Android's Google Play Store where it can be downloaded free of charge. By downloading Huawei Mobile WiFi App you can move the device to a stronger signal area, manage the device remotely and monitor battery and signal performance. It also supports reading SMS, sharing the status of connected devices and remote configuration.
By using Mobile Broadband devices you can access the Mobile Internet, rather than having to rely on traditional fixed line Internet access at home or in the office. Just imagine being able to access the Internet wherever you are - out socialising in the pub, at a campsite with the kids who can play games from their WiFi gaming console or travelling to a work meeting on the train and needing to log on to your work email. In the past, a barrier to widespread Mobile Broadband usage was the fact that the mobile network coverage (especially in non urban areas) was limited and mobile data speeds much slower. Today, mobile networks are offering widespread mobile coverage and faster data speeds of up to 150Mbps* on some 4G networks and 42Mbps* on some 3G networks. This allows users to access the Internet when they are out and about, on public transport and at home or at work. Most Mobile Broadband devices are really competitively priced, easy to set up and convenient to use. Depending on the device you select, they are also ultra compact - fitting discretely into your purse, pocket and in some cases your wallet. *Network dependent
What's in the box?
-Device -Battery -UK Mains Charger -USB Data Cable -Quick Start Guide
