Click to visit BT.com
HP StorageWorks X1600 6TB SATA Network Storage System
HP HP StorageWorks X1600 6TB SATA Network Storage System
Quicklinx: 69Y0WS00
Mfr#: AP788A
£6,602.88 inc VAT
You have better things to do than worry about storage. You're juggling multiple management interfaces, security concerns, and shrinking backup windows - all while your users demand more and more space. You need a shared storage solution that's powerful and easy to manage, and you need it now.
HP StorageWorks X1000 Network Storage Systems are the fast and easy way to add Windows-powered shared storage to your small or medium IT environment. They're versatile unified storage, so you get more for your money since it can be a file server, an iSCSI target for application/virtual environment storage, or both. You'll spend less time and effort on maintenance and management once you consolidate to a centralized shared storage system, and industry standards will protect your investment by providing compatibility with your network and applications.
HP X1600 Network Storage System delivers high capacity and high performance and drive down your cost per GB. Quad-Core processing and ready external expandability enhance this ultra-dense 2U shared storage solution for small, medium, and workgroup environments.
Image gallery
Select any thumbnail below to view a larger image.
HP StorageWorks Network Storage System X1600 6TB SATA Model - NAS server
NAS server
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
6 TB
6 (installed) / 12 (max)
1 x Intel Xeon E5520 2.26 GHz ( Quad-Core )
Storage Controller
RAID - Serial Attached SCSI - RAID 0, 1, 5, 10, 50
Hard Drive
6 x 1 TB hot-swap Serial ATA-300
Optical Storage
1 x DVD-RW
Network adapter - integrated - Ethernet, Fast Ethernet, Gigabit Ethernet
NAS server
Enclosure Type
Rack-mountable - 2U
6 TB
Processor / Memory
Processors Installed
Multi-Core Technology
Quad-Core
Max Supported Qty
1
RAM Installed
DRAM 6 GB (installed) / 32 GB (supported)
Storage Controller
RAID
Controller Interface Type
Supported Devices
Hard drive
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
Cache / Buffer Size ( Max )
256 MB
Hard Drive
Hot-swap - 3.5" x 1/3H
6 x 1 TB
Interface Type
Serial ATA-300
Spindle Speed
7200 rpm
Optical Storage
1 x DVD-RW
Network / Transport Protocol
TCP/IP
Expansion Bays
12 (total) / 6 (free) x hot-swap - 3.5" x 1/3H
Expansion Slot(s)
18 (total) / 15 (free) x memory , 2 PCI Express x8
2 x power cable
Power supply - redundant
Power Provided
750 Watt
Accessories
1-10 products displayed out of 19
Page 1 2
  product description   In stock inc VAT qty
  HP 2GB Dual Rank x8 PC3-10600 HP 2GB Dual Rank x8 PC3-10600
quicklinx: 5LCHWS00 | Mfr#: 500656-B21
In stock £61.60
  HP 4GB Dual Rank x4 PC3-10600 (DDR3-1333MHz) HP 4GB Dual Rank x4 PC3-10600 (DDR3-1333MHz)
quicklinx: 62FCWS00 | Mfr#: 500658-B21
In stock £107.01
  HP StorageWorks RDX320 External Removable Disk Backup HP StorageWorks RDX320 External Removable Disk Backup
quicklinx: 6Z4HWS00 | Mfr#: AJ768A
In stock £437.47
  HP Ultrium 1760 SAS Ext Tape Driv HP Ultrium 1760 SAS Ext Tape Driv
quicklinx: 562GWS00 | Mfr#: EH920A
Available £2,223.90
  HP G6 750W High Efficiency Power Supply Option Kit HP G6 750W High Efficiency Power Supply Option Kit
quicklinx: 62QWWS00 | Mfr#: 512327-B21
Available £229.05
  HP Smart Array P212 SAS Controller with Zero Cache HP Smart Array P212 SAS Controller with Zero Cache
quicklinx: 62RVWS00 | Mfr#: 462828-B21
Available £151.38
  HP Smart Array P411/512MB BBWC Storage Controller HP Smart Array P411/512MB BBWC Storage Controller
quicklinx: 64QTWS00 | Mfr#: 462832-B21
Available £409.22
  HP Smart Array P212 SAS Controller with 256MB Cache HP Smart Array P212 SAS Controller with 256MB Cache
quicklinx: 65B8WS00 | Mfr#: 462834-B21
Available £276.93
  HP StorageWorks RDX160 External Removable Disk backup HP StorageWorks RDX160 External Removable Disk backup
quicklinx: 6D30WS00 | Mfr#: AJ766A
Available £281.64
  HP NC522SFP+ PCI Express Dual Port 10GbE Server Adapt HP NC522SFP+ PCI Express Dual Port 10GbE Server Adapt
quicklinx: 6LMSWS00 | Mfr#: 468332-B21
Available £610.57
Page 1 2
feature value
Type NAS server
Controller Type RAID
Brand HP
Price Range Inc VAT 1500+
