Click to visit BT.com
HP Probook 4515sTur M500 2 250
HP HP Probook 4515sTur M500 2 250
Quicklinx: 69JYWS00
Mfr#: VC410EA#ABU
The HP ProBook 4515s notebook PC boasts a sleek design that packs an array of features normally reserved for more expensive notebooks. With a more spacious keyboard layout and separate numeric keypad, it delivers refined simplicity with a clean design and the Turion II mobile processor. The low-profile 15.6-inch display gives you improved brightness, contrast and clarity with a screen that is more power-efficient than regular LCD screens.
Image gallery
Select any thumbnail below to view a larger image.
  • Built to protectIntegrated, customizable security solutions help defend your network, your applications, and your data.
  • Built to lastHP 3D DriveGuard helps protect your notebook's hard drive against impact, bumps, or drops using a three-axis accelerometer which detects any sudden movement and initiates protective action, so your critical information is protected while you are on the move.
  • Built to conserveHP business Notebook PCs are designed to reduce their impact on the environment by eliminating or reducing substances of concern, using fewer resources, reducing energy consumption, and designing for recyclability.
HP ProBook 4515s - 15.6" - Turion II M500 - Windows 7 Professional - 2 GB RAM - 250 GB HDD
System Type
Notebook
Operating System
AMD Turion II mobile processor M500 / 2.2 GHz / 1 MB Cache
2 GB DDR2
Storage
250 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti DL
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
ATI Radeon HD 3200
802.11b/g, Bluetooth 2.0 EDR , Gigabit Ethernet , fax / modem
6-cell - up to 3.75 hours
37.2 cm x 25 cm x 3.2 cm
2.6 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
1 year warranty
System Type
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional
1 year warranty
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
RAM
2 GB ( 1 x 2 GB )
Max RAM Supported
8 GB
DDR2 SDRAM
Speed
800 MHz / PC2-6400
SO DIMM 200-pin
Slots Qty
2
Empty Slots
1
Storage
Hard Drive
Serial ATA-300
Optical Drive
DVD±RW (±R DL) / DVD-RAM - fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 4x (DVD±R DL)
CD / DVD Rewrite Speed
16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Disc Labeling Technology
LightScribe Technology
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 ( HD )
Widescreen
Image Aspect Ratio
16:9
Anti-glare
Audio & Video
Graphics Processor
ATI Radeon HD 3200
Memory Allocation Technology
HyperMemory up to 896MB
Camera
Integrated webcam
Resolution
2 Megapixel
Sound
Stereo speakers , microphone
Codec
AD1984JCPZ
High Definition Audio
Input
Keyboard, touchpad
Built-in numeric keyboard
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Broadcom 4312G
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP
Wi-Fi CERTIFIED
Modem
Protocols & Specifications
ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Fax Compatibility
G3
Max Transfer Rate
56 Kbps
6-cell Lithium Ion
47 Wh
Run Time
Up to 3.75 hours
AC Adapter
Input
AC 120/230 V ( 50/60 Hz )
Connections & Expansion
Slots
1 x ExpressCard/34 ( 1 free )
HDMI , VGA , Headphone output , Microphone input , LAN , 4 x USB 2.0 , Modem
Memory Card Reader
Yes ( SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, Memory Stick Duo, xD-Picture Card )
Software
Software Included
Intervideo WinDVD, WinZip, HP Quick Launch Button Software, Synaptics Touchpad Driver, Skype, HP Help and Support Center, HP QuickLook 2, Roxio Creator Business Edition, HP Webcam Software, PDF Complete Special Edition, HP SoftPaq Download Manager, HP Recovery Manager
Security lock slot (cable lock sold separately), system password, power-on password, memory change alert, ownership tag, HP Disk Sanitizer, HP 3D DriveGuard, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer
FCC Class B certified, CSA, UL, VCCI, BSMI, GOST, CISPR 22 Class B, EN 60950, NORDIC, SABS, IEC 60950, UL 60950, EN55022 Class B, CCC, MIC, ICES
Localization
37.2 cm
25 cm
3.2 cm
2.6 kg
EPEAT Compliant
EPEAT Gold
Limited warranty - battery - 1 year
5 °C
35 °C
10 - 90%
Shock Tolerance
125 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
Accessories
1-10 products displayed out of 15
Page 1 2
  product description   In stock inc VAT qty
  HP Executive Carry Case HP Executive Carry Case
quicklinx: 4RWPWS00 | Mfr#: RR316AA
In stock £59.66
  HP Carrying Case for upto 15.6" Laptops HP Carrying Case for upto 15.6" Laptops
quicklinx: 5CNKWS00 | Mfr#: AJ078AA
In stock £13.86
  HP SMART 230W AC ADAPTER HP SMART 230W AC ADAPTER
quicklinx: 7747WS00 | Mfr#: AT895AA
In stock £77.66
  HP LCD Monitor Stand - Monitor stand with port replicator shelf HP LCD Monitor Stand - Monitor stand with port replicator shelf
quicklinx: 7M89WS00 | Mfr#: QM196AA
While Stocks Last £115.83
  HP USB 2.0 Optical Scroll Mouse HP USB 2.0 Optical Scroll Mouse
quicklinx: 2N8QWS00 | Mfr#: DC369A
Usually shipped in 3 days £7.89
  HP USB Optical Travel Mouse HP USB Optical Travel Mouse
quicklinx: 4H71WS00 | Mfr#: RH304AA
Usually shipped in 3 days £8.72
  HP Care Pack Next Business Day Hardware Support extended service agreemen- Notebook Only HP Care Pack Next Business Day Hardware Support extended service agreemen- Notebook Only
quicklinx: 562MWS00 | Mfr#: UK704E
Usually shipped in 3 days £129.52
  HP AC Smart Adapter - 90W HP AC Smart Adapter - 90W
quicklinx: 57ZJWS00 | Mfr#: ED495ET#ABU
Usually shipped in 3 days £54.06
  HP 90W Smart AC/Auto/Air Combo HP 90W Smart AC/Auto/Air Combo
quicklinx: 5BH9WS00 | Mfr#: AJ652AA#ABU
Usually shipped in 3 days £91.92
  HP USB PORT REPLICATOR HP USB PORT REPLICATOR
quicklinx: 67LKWS00 | Mfr#: AQ731AA
Usually shipped in 3 days £71.48
Page 1 2
