Click to visit BT.com
HP LaserJet Pro P1102 - printer - B/W - laser
HP HP LaserJet Pro P1102 - printer - B/W - laser
Usually dispatched within 3 working days
Quicklinx: 6MQLWS00
Mfr#: CE651A#B19
£70.80
HP LaserJet P1102w Printer
Network Connectivity in your home or office[1].
- Network the printer without extra cables [1].
- Print documents fast at up to 18 ppm A4.
- Get a first printed page out in as fast as 8.5 seconds from Powersave mode (Auto-Off), with Instant-on Technology.
- Print on a wide variety of media types including card stock, transparencies, labels and envelopes, using the 150-sheet paper tray and 10-sheet priority input slot[2].
Experience easy, reliable, mobile HP LaserJet printing.
- Print from virually anywhere with HP ePrint[3]. Easily print from smartphones or other Internet-capable devices. And with AirPrint™ you can simply print wirelessly from your iPad®, iPhone®, and iPod touch®[4].
- Install in a flash with HP Smart Install[5] - no CD required.
- Set up and start printing right away with an easy-to-use, intuitive control panel with LED lights.
- Receive consistent results with Original HP cartridges designed for your printer, and easily reorder with HP SureSupply[6].
Reduce your environmental impact and protect your bottom line.
- Get up to 50 percent energy savings over competitive laser products, using Instant-on Technology[7].
- Achieve additional, effortless savings with HP Auto-On/Auto-Off Technology[8].
- Reduce wasted paper by printing only the content you want, using HP Smart Web Printing[9].
- HP helps reduce your environmental impact with less packaging, plus free cartridge recycling with HP Planet Partners[10].
- Save space with an ultra-compact printer with a sleek, industrial design.
Create professional, cost-effective prints.
- Produce professional-quality business prints: HP spherically shaped toner consistently delivers bold, crisp text and sharp images.
- Receive improved print quality with HP FastRes 1200[11] which produces smaller print files, crisp text, even tones and smooth business graphics.
[1] Wireless printing is only available on the HP LaserJet Pro P1102w Printer. Wireless performance is dependent upon physical environment and distance from access point, and may be limited during active VPN connections.
[2] 10-sheet priority input slot is only available on the HP LaserJet Pro P1102w Printer.
[3] Requires an Internet connection to the printer. Feature works with any connected Internet- and email-capable device. Print times may vary. Some HP LaserJets may require a firmware upgrade. For a list of supported documents, and image types, see www.hp.com/go/eprintcenter. And for additional solutions, see www.hp.com/go/mobile-printing-solutions. Available only on the HP LaserJet Pro P1102w Printer.
[4] Supports iOS 4.2 devices (iPad, iPhone 4, iPhone 3GS, and 3rd and 4th generation iPod touch) that support multitasking. Works with HP ePrint-enabled printers and all-in-ones. AirPrint and iOS 4.2 devices require an 802.11 wireless network connection to the printer. Wireless performance is dependent upon physical environment and distance from the access point. AirPrint and the AirPrint Logo are trademarks of Apple Inc. iPad, iPhone, and iPod touch are trademarks of Apple Inc., registered in the U.S. and other countries. Available only on the HP LaserJet Pro P1102w Printer.
[5] HP Smart Install works with Windows only.
[6] Programme features and availability may vary by country. For more information, visit www.hp.com/learn/suresupply.
[7] Energy savings based on HP testing using the ENERGY STAR® programme's Typical Energy Consumption (TEC) method on HP LaserJet products with Instant-on Technology vs. top competitive models as of March 2009.
[8] HP Auto-On and Auto-Off capabilities subject to printer and settings.
[9] This feature needs Microsoft Internet Explorer 6.0 or higher.
[10] Programme availability varies. HP print cartridge return and recycling is currently available in more than 50 countries and territories around the world through the HP Planet Partners programme. For more information, or to request return envelopes and bulk collection boxes, visit www.hp.com/recycle.
[11] HP FastRes 1200 provides the best print quality setting for this device. Choose HP FastRes 600 for fast printing.
Image gallery
Select any thumbnail below to view a larger image.
Printer Type
Personal printer - laser - monochrome
34.9 cm x 23.8 cm x 19.6 cm
5.2 kg
Max Media Size (Standard)
A4
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm)
Max Resolution ( B&W )
1200 dpi x 1200 dpi
Image Enhancement Technology
HP FastRes 1200
USB
266 MHz
RAM Installed ( Max )
2 MB ( 2 MB )
Media Type
Envelopes, transparencies, labels, plain paper, photo paper, postcard, vellum paper, cards, recycled paper
Total Media Capacity
150 sheets
Monthly Duty Cycle
5000 pages
Recommended Monthly Volume
250 - 1500 pages
Microsoft Windows Server 2003, Microsoft Windows Vista / XP / 7, Apple MacOS X Server 10.4 or later, Microsoft Windows Server 2008
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Printer Type
34.9 cm
23.8 cm
19.6 cm
5.2 kg
Printer
Print Speed
Wired
USB
1200 dpi x 1200 dpi
HP FastRes 1200
First Print Out Time B/W
8.5 sec
266 MHz
RAM
2 MB / 2 MB (max)
Media Handling
Media Type
216 mm x 356 mm
Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
Media Weight
60 g/m2 - 163 g/m2
150 sheets
Media Feeder(s)
1 x autoload - 150 sheets weight: 60 g/m2 - 163 g/m2
Output Trays Capacity
100 sheets
Duty Cycle
Monthly Duty Cycle
5000 pages
250 - 1500 pages
1 x USB - 4 PIN USB Type B
Power supply - internal
Frequency Required
50/60 Hz
360 Watt
Power Consumption Stand by / Sleep
1.4 Watt
Software Included
Drivers & Utilities
1 year warranty
Service & Support Details
Limited warranty - parts and labour - 1 year
15 °C
32.5 °C
10 - 80%
Accessories
1-3 products displayed out of 3
  product description   In stock inc VAT qty
  HP Office Paper - Plain paper - A4 (210 x 297 mm) - 500 sheet(s) - 80 g/m2 HP Office Paper - Plain paper - A4 (210 x 297 mm) - 500 sheet(s) - 80 g/m2
quicklinx: 2327WS00 | Mfr#: CHP110
In stock £4.44
  HP No 85A - Toner cartridge - 1 x black HP No 85A - Toner cartridge - 1 x black
quicklinx: 6MQRWS00 | Mfr#: CE285A
In stock £54.09
  HP Photo laser paper matt A4     HP Photo laser paper matt A4
quicklinx: 3F2MWS00 | Mfr#: Q6544A
Usually shipped in 3 days £12.00
feature value
Type Printer
Output Type Monochrome
Wireless Capability Wired
Technology Laser
Max Print Speed 18ppm
Printer Type Personal printer
Brand HP
Price Range Inc VAT 50 - 100
