Click to visit BT.com
HP LA1951G 19" 1280 x 1024 5ms DVI-D VGA LCD Monitor
HP HP LA1951G 19" 1280 x 1024 5ms DVI-D VGA LCD Monitor
12 In stock
Quicklinx: 6KXYWS00
Mfr#: EM890AT#ABU
£151.47
HP Compaq LA1951g 19-Zoll-LCD-Monitor
Be comfortable and productive while you reduce your energy bill with the advantage series HP LA1951g 19-inch LCD monitor, which meets ENERGY STAR 5.0.
Image gallery
Select any thumbnail below to view a larger image.
HP Compaq LA1951G - LCD monitor - 19"
LCD monitor - 19"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Input Connectors
DVI-D, VGA
Display Position Adjustments
Screen Coating
Anti-glare, anti-static
41.4 cm x 30.1 cm x 37.8 cm
7.3 kg
English / United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified , EPEAT Gold
Plug and Play, CSA, TUV, VCCI, BSMI CNS 13438 Class B, CCIB, cUL, GS, EN55022 Class B, FCC Part 15 B, CCEE, EN55024 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, TCO Displays 5.0, ISO 9241-307, KCC, CISPR, GEEA, AS/NZS 3548 Class B
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m2
Contrast Ratio
1000:1
Response Time
5 ms
Vertical Refresh Rate
77 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
140 MHz
Horizontal Viewing Angle
160
Vertical Viewing Angle
160
Screen Coating
Colour Temperature
6500K
Controls & Adjustments
Brightness, contrast, H/V position, H/V size, input select, colour temperature, phase, clock
OSD Languages
Chinese (simplified), English, German, French, Italian, Spanish, Dutch, Japanese
AssetControl
7.3 kg
DVI-D , VGA , 2 x USB
Mechanical
Tilt Angle
40
Flat Panel Mount Interface
100 x 100 mm
Stand
1 x USB cable , 1 x VGA cable - 1.8 m , 1 x DVI cable
Backlight Life
40,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
44 Watt
Power Consumption Stand by / Sleep
2 Watt
EPEAT Compliant
EPEAT Gold
5 °C
35 °C
20 - 80%
Accessories
1-3 products displayed out of 3
  product description   In stock inc VAT qty
  HP Quick Relase Bracket for TFT HP Quick Relase Bracket for TFT
quicklinx: 4RPNWS00 | Mfr#: EM870AT
Usually shipped in 3 days £37.08
  HP Flat Panel Speaker Bar HP Flat Panel Speaker Bar
quicklinx: 6KZXWS00 | Mfr#: NQ576AT
Usually shipped in 3 days £25.59
  HP Adjustable Display Stand HP Adjustable Display Stand
quicklinx: 74K7WS00 | Mfr#: AW663AA#AC3
Usually shipped in 3 days £99.60
feature value
Diagonal Size 19in
Max Resolution 1280 x 1024
Response Time 5ms
Speakers None
Interfaces DVI
Interfaces VGA (HD-15)
Colour Silver
Brand HP
Stock Status In Stock
Price Range Inc VAT 150 - 300
