Click to visit BT.com
Generic B-Tech LCD TV/Panel Wall Mount - Suitable for up to 32" Models
Generic Generic B-Tech LCD TV/Panel Wall Mount - Suitable for up to 32" Models
Quicklinx: 6ZVSWS00
Mfr#: BT7515B
The B-Tech 7515
The BTech 7515 is a double articulated LED / LCD wall mount. The two arm construction allows the screen to be pulled from the wall up to 525mm. The free moving pivots allow the tv to be positioned in the optimum viewing position. The BT 7515B wall bracket will fold back to the wall with only 110mm of clearance between the wall and your flat screen tv.
  • Tilts 40º up and down
  • 3 Pivot points for maximum swivel, suitable for corner mounting
  • Max Load 25Kg
  • GS/TUV certified
  • A VESA hole pattern for small screens can be of several sizes The BT7515 has 75mm x 75mm, 100mm x 100mm, 200mm x 100mm and 200 x 200mm
  • Suitable for LCD/LED/TFT Screens upto 42" and 25Kgs
  • Metal construction
  • Maximum Extension 525mm
  • Folds flat to the wall
  • Simple installation , all fixings included
  • Suits most Samsung LE23 - 32 inch as well as LCDTVs with VESA 75, 100 & 200 x 100
Image gallery
Select any thumbnail below to view a larger image.
