Click to visit BT.com
Fujitsu fi-6770 A3 VRS Pro Scanner
Fujitsu Fujitsu fi-6770 A3 VRS Pro Scanner
Usually dispatched within 3 working days
Quicklinx: 5GT2WS00
Mfr#: PA03576-B001
£6,177.12 inc VAT
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6770 production scanner. Designed with outstanding paper handling, high scan speeds of up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6770 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6770's innovative intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents such as photos, label stickers, or taped-on receipts.
In keeping with Fujitsu's long-standing commitment to safeguarding the environment, the fi-6770 is the business scanner to adhere to strictest ecological regulations throughout the entire manufacturing process. The design and manufacture of the fi-6770 meet Energy Star's energy consumption requirements and the European Union's Reduction of Hazardous Substances and Volatile Organic Compounds regulations.
Image gallery
Select any thumbnail below to view a larger image.
Fujitsu fi 6770 - document scanner
Document scanner - desktop
Max Supported Document Size
ANSI B (Ledger) (279 x 432 mm)
50 cm x 69 cm x 34.3 cm
35 kg
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
279 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Autoload
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
Interface Type
Ultra SCSI / Hi-Speed USB
AC 120/230 V ( 50/60 Hz )
Environmental Standards
ENERGY STAR Qualified
50 cm
69 cm
34.3 cm
35 kg
Scanner
Input Type
Grayscale Depth
10-bit grey
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
15000 scans per day
Scanner Features
Ultrasonic Double Feed Detection
TWAIN, ISIS
Media Handling
Max Document Size
279 mm x 432 mm
Plain paper
Autoload
200 sheets
Ultra SCSI - 68 pin HD D-Sub (HD-68) , 1 x Hi-Speed USB - 4 PIN USB Type B
Power supply - internal
Power Consumption Operational ( Standby )
216 Watt ( 6 Watt )
Software Included
Drivers & Utilities, QuickScan (Demo), Adobe Acrobat Standard, ScandAll Pro, Soft IPC (demo), Kofax VirtualReScan 4.2 Professional
5 °C
35 °C
20 - 80%
Sound Emission
53 dB
Accessories
1-2 products displayed out of 2
  product description   In stock inc VAT qty
  Fujitsu fi-6770 3yr 5x8 warranty Fujitsu fi-6770 3yr 5x8 warranty
quicklinx: 6M86WS00 | Mfr#: OS-36-580-6770
Ordered upon request £1,297.17
  Fujitsu Consumable Kit fi-6670/fi-6670A/fi-67 Fujitsu Consumable Kit fi-6670/fi-6670A/fi-67
quicklinx: 77HFWS00 | Mfr#: CON-3576-012A
Available £637.86
feature value
Type Document scanner
Form Factor Desktop
Max Paper Size ANSI B (Ledger) (279 x 432 mm)
Interface Ultra SCSI
Compatibility PC
Brand Fujitsu
Price Range Inc VAT 1500+
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Nintendo DSi Black
Nintendo DSi Black
£145.90 inc VAT
HP JetDirect 635N
HP JetDirect 635N
£463.09 inc VAT
BT Hub Phone 2.1
BT Hub Phone 2.1
£69.87 inc VAT
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
