Fuji FinePix AX650 Red Camera Kit including 4GB SD Card, Case, AA Batteries and Charger
free standard delivery
Key features
  • Fujinon 5x zoom lens and 14 megapixels
  • High sensitivity ISO3200
  • Digital image stabilization
  • 2.7-inch monitor
Product codes
chevron icon
chevron icon
Designed to be the ultimate in simplicity, the easy-to-use AX650 features a 16-megapixel CCD sensor that captures large, high quality images, a precision Fujinon 5x optical zoom that Lens brings the action closer, and a bright 2.7" LCD makes shooting and viewing a snap. The AX650 also features the SR AUTO function which allows the camera to automatically determine difficult shooting conditions and maximize performance, for a great shot time after time. Combine all this with the convenience of AA battery operation for a simple to use value solution for the everyday picture taker.
chevron icon
Product Description Fujifilm FinePix AX650 - digital camera - Fujinon
Product Type Digital camera - 720p - compact
Lens Included Fujinon
Memory Card Slot SD card
Sensor Resolution 16.0 Megapixel
Max Video Resolution 1280 x 720
Lens System Zoom lens - 5x zoom - 5.9 - 29.5 mm - f/3.3-5.9
Focus Adjustment Automatic
Min Focus Distance 45 cm
Digital Zoom 7.2x
Image Stabiliser Electronic
Camera Flash Built-in flash
Display LCD display - 2.7"
Supported Battery 2 x AA alkaline battery (included) , AA NiMH rechargeable battery (optional)
Interface Composite video/audio, USB 2.0
Colour Red
Dimensions (WxDxH) 9.3 cm x 2.78 cm x 6.02 cm
Weight 119 g
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
