Click to visit BT.com
Edimax Wireless-N 150Mbps Mini USB Adapter
Edimax Edimax Wireless-N 150Mbps Mini USB Adapter
Quicklinx: 625CWS00
Mfr#: EW-7711UTN
Incredible high-speed wireless network access
Customer rating
4.0*
View reviews
EW-7711UTn is a mini-size wireless USB adapter which provides a simple and easy way to add or upgrade wireless connectivity to your desktop or notebook computer. This nLITE mini-size USB adapter supports higher data rate up to 150Mpbs when connecting with wireless 802.11n device. You can just plug it into computer's USB port and enjoy incredible high-speed wireless network access.
Compatible with wireless 802.11n devices with data rate up to 150Mbps
EW-7711UTn complies with wireless IEEE802.11b/g standards. With built-in with the latest wireless technology, EW-7711UTn can increase the coverage 3 times more and reduce "dead spots" within the wireless range. The transmission data rate when connecting with wireless 802.11n devices is up to 150Mbps, which makes signal travel farther and maintain wireless connections much reliable than standard wireless IEEE802.11b/g network.
Supports WPS-compatible (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS-compatible configuration and hardware WPS push button. When both ends of the wireless connection use wireless solution with WPS, it will automatically configure the wireless network with robust WPA data encryption and authentication.
Supports multi-language EZmax setup wizard
The included 16 languages EZmax setup wizard and friendly UI will walk you through configuring EW-7711UTn to your wireless network.
Portable and compact design
The compact design of EW-7711UTn is convenient to carry for all mobile users.
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Edimax Wireless-N 150Mbps Mini USB Adapter
Customer reviews read all 7 customer reviews
Write a review for the Edimax Wireless-N 150Mbps Mini USB Adapter here!
Great Little Gadget
Reviewed by A Caplen. Review Posted 17/11/2010
I have just bought this little wireless adapter and plugged it into my desktop computer which does not have a wireless card as it is somewhat older than my laptop, but still useful, adding this little dongle was a great idea and I have to say it does a great job and it was so cheap, I ran the disc again because the first time it was not good but then it started working and just like they say in the discription it is a powerful little gadget
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
low standard
Reviewed by Anonymous Review Posted 16/10/2010
I bought the item above and was disapointed with its performance. The output a mere 65Mbps an increase of 11Mbps,hardly worth the bother and certainley not worth the cost
  • Overall 5*
  • Ease of use 5*
Disappointing
Reviewed by Dennis Parker. Review Posted 14/10/2010
I was looking for something to improve the signal strength and speed in one room of the house where it is very low and often not at all. The description of this product seemed to be ideal. Once installed, I was left with no signal where I was hoping to improve and considerably reduced signal strength in other parts of the house where I normally have excellent strength. As a result I have returned to my original set-up and put this product away, in short a waste of time.
  • Overall 5*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Hi-Speed USB
Compatibility
PC
Manufacturer
Edimax Technology
Wired / Wireless
Wireless
Network adapter
Plug-in card
Protocol
IEEE 802.11n
IEEE 802.11b
Hi-Speed USB
IEEE 802.11g
Product Line
Edimax
Speed
150
Model
EW-7711UTn
Standards
USB 2.0
IEEE 802.11n
IEEE 802.11b
IEEE 802.11g
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
