Edimax Wireless N 150 Dual Mode IP Camera
Live Streaming Video
The Edimax IC-3005 series is tailor made to stream live video over your network. You can view the IP camera's video from anywhere on your local computers or via the Internet. The Edimax IC-3005 series includes software that allows you to view up to 16 cameras' images simultaneously.*
High Quality and speed. Supports MPEG4 and M-JPEG
The Edimax IC-3005 series features high quality and high frame rate video streaming through advanced video compression. In order to achieve the highest video quality, simply select MPEG4 or M-JPEG depending on your network settings.
Features Multi-Area Motion Detection
The Edimax IC-3005 series is a powerful mobile surveillance system with intelligent multi-area motion detection. Pre-determine 3 areas on your streaming video for motion detection to effectively monitor your home, pets or business. When motion is detected in one of these areas, the camera records and sends footage of the events to E-mail or FTP server.
Records Video Clips
Record video clips and replay at a time of your convenience. Set a schedule for recording or manually activate recording whenever you wish to.
Supports DDNS** and UPnP
With DDNS you can access the Edimax IC-3005 IP Camera by typing in an easy-to-remember URL rather than typing in an IP address in your web browser. DDNS is also ideal for those without a fixed public IP address. UPnP allows Windows XP/Vista/7 users to access the device with the simple click of a mouse button.
Supports MPEG4 and M-JPEG Dual mode video streaming
High speed hardware based compression
Features multi-area motion detection and snapshot to E-mail and FTP
Features fixed focus lens
Supports Up to 30 fps Video Frame Rate
Includes easy-to-view 16-channel viewer to view up to 16 cameras simultaneously*
Supports 16 additional user accounts for viewing camera
Manual/Schedule/Cycle recording and Playback/Forward/Pause/Stop video with the software utility
Supports Windows 2000/XP/Vista/7
Firmware Upgradable
