Click to visit BT.com
BT.com
Wishlist
Edimax Wireless-N (802.11n) Range Extender
Customer rating:4.0*
Quicklinx: 5BR5WS00
Mfr#:
PC Pro logo
Wireless 802.11n Access Point
Acting as a bridge between the wired Ethernet and the 2.4GHz wireless IEEE 802.11b/g/n, this wireless access point let your wireless client stations access both the wired and the wireless network nodes.
Universal Repeater Mode
The Universal Repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schools.
Robust Wireless Security with WPA and WPA2
Except for the basic security control by ESSID and 64/128 bit key length WEP encryption, this access point also supports the advanced security features, like MAC access control, IEEE 802.1x authentication, TKIP, AES and hidden ESSID. It provides a total solution for you to build up a secure wireless network environment that can prevent from all kinds of hacker intrusion.
Web Configuration
You can configure this access point through the friendly Web user interface with a browser.
  • Wireless 802.11n access point
  • Universal repeater mode
    The universal repeater function could extend the coverage and signal strength for the current wireless environment. This standardized function is compatible with other wireless APs and Routers. Users can use this feature to build up a large wireless network in a huge space like airports, hotels and schoolsetc.
  • Robust wireless security with WPA and WPA2
  • Web configuration
Edimax EW-7416APn - radio access point
Radio access point
External
RAM
16 MB
Flash Memory
4 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Frequency Band
2.4 GHz
Microsoft Windows 95/98, Microsoft Windows 2000 / ME / XP/ Vista
12.7 cm x 9.6 cm x 3 cm
Radio access point
12.7 cm
9.6 cm
3 cm
Processor / Memory / Storage
RAM
16 MB SDRAM
Flash Memory
4 MB
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
DHCP support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, Wi-Fi Protected Setup (WPS), DHCP server, hidden SSID
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft)
Aerial
Antenna
External detachable
Antenna Qty
2
Gain Level
3 dBi
1 x 100Base-TX - RJ-45
FCC, RoHS
External power adapter
10 °C
10 - 90%
Customer reviews
Write a review for the Edimax Wireless-N (802.11n) Range Extender here!
Works with BT Home Hub 3
Reviewed by Anonymous Review Posted 17/12/2012
Slight limitation with not working with WPA2, but as I can use WPA with home hub 3 then it b is fine. Setup was straightforward (checked online before buying if compatible with home hub) and have had no problems since. Even got wii online without too many problems. Overall very pleased as it brings better signal to front of the house
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Slight hiccup but working fine
Reviewed by Colin Carlson. Review Posted 19/04/2011
Having read the other reviews, and being of an age that says "Technology Passed me by a long time ago", I decided to have a go. Living in a very old house with 2 foot thick stone walls, my BT home hub doesn't get very far and so I desperately needed to increase its range for my internet radio, amongst other things.
When it arrived I switched on the unit and managed to find it after 5 mins of searching, tried the network settings in the control panel, but no! Finally clicked on the network icon at the bottom right of the screen and there it was so hit connect.
Now went to the setup wizard on the CD and it found it and said enter your user name and password, which is shown on the bottom of the unit, so duly entered it and got told it was incorrect! (10 times).
Now giving up on it so BT can have it back, but as a final idea went on to Edimax web and there is the answer. Don't try and set it up wirelessly, you must hard wire it to your computer, and away it goes.
Now working fantastic!
  • Overall 5*
  • Ease of use 4*
Edimax Wilreless-N Range Ext. Version2
Reviewed by Maria. Review Posted 21/10/2010
Reading these reviews I was almost ready to give up on Edimax, but since these reviews are almost one year old I wouldn't disregard this brand just yet. I also have a HomeHub2 and yes it is WPA2 encrypted, which made it useless if you used Edimax first version(wireless-N Range Extender EW-7416APn), since for it to function properly you'd have to change to WEP encryption on your HomeHub2. A new Edimax Version2 is out and it caters for the issue that (Peter Smith) has mentioned. This Version2 supports WPA and WPA2. You can make your decision by going to their uk website: http://www.edimax.co.uk/en/produce_detail.php?pd_id=307&pl1_id=1&pl2_id=5
  • Overall 5*
  • Ease of use 5*
Edimax Wireless-N (802.11n) Range Extender.
Reviewed by Peter Smith. Review Posted 05/12/2009
This device is actually one of the easiest on the market to set up. The problem is that BT should not be promoting it as suitable for connecting to the HomeHub 2, since their equipment is WPA2 encrypted. I contacted Edimax, who were helpful. The range extender in universal repeater mode, only operates with BT equipment in WEP encryption. Since everything else on my home network is WPA2 encrypted with the HomeHub, I would have to change the whole network to WEP to get this to function.
It is time that this was sorted out. The HomeHub is good but does not link with any other universal repeaters. I have tried Belkin and PheeNet devices and encountered the same problem. Please BT, get a unversal repeater that will simply plug and play. There is a real market out there amongst people living in older homes with thicker walls, who struggle with wireless connections.
  • Overall 3*
  • Ease of use 3*
  • Value for money 3*
Edimax Range extender - useless
Reviewed by Anonymous Review Posted 12/11/2009
I spent a few hours unsuccessfully trying to get it to talk to my BT HomeHub2. I even had the BT Broadband guy try, unsuccessfully. Don't waste your money and time on this piece of junk.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
