Edimax IC-3010 is a Fast Ethernet network camera tailored to stream live video over your network. Video can be viewed anywhere from your local computers and even over the Internet.
IC-3010 supports dual-mode video compression. You can choose M-JPEG mode or MPEG4 mode according to your network settings in order to achieve the highest video quality.
The IC-3010 forms a powerful mobile surveillance system. With the intelligent multi-area motion detection function, it helps monitoring your home, pets or business effectively. You can pre-determine 3 areas on your streaming video for motion detection. Whenever motion is being detected in these areas, the camera takes a snapshot automatically and the picture of the events can be sent to email or ftp server.
With the built-in microphone and audio output for connecting to external speaker, IC-3010 can support 2-way audio allowing you to remotely talk to anyone at the camera site. This is also an ideal solution for video conference.
You can record the video clips manually or based on a predetermine schedule so that you can replay the video in your convenience.
You can view your camera on your iPhone with the Edimac eCam app!
Select any thumbnail below to view a larger image.
The following resources are available for the Edimax Dual-Mode 1.3M IP Camera
