Click to visit BT.com
Edimax 300Mbps Wireless N USB Adapter
Edimax Edimax 300Mbps Wireless N USB Adapter
47 In stock
Quicklinx: 79FNWS00
Mfr#: EW-7622UMN
Spring Clearance! Was £17.36
£14.04
Customer rating
1.0*
View reviews
Simply plug your new Edimax EW-7622UMn USB adapter into your computer's USB port, and enjoy high-speed wireless network access. This mini wireless USB adapter provides a simple and easy way to add or upgrade the wireless connectivity of your desktop, laptop or notebook computer. You can enjoy high data transfer rate at up to 300Mbps when your Edimax EW-7622UMn USB adapter is connected with wireless 802.11n-compatible devices.
Wireless 802.11n Standard (data rates up to 300Mbps)
Edimax EW-7622UMn provides extended wireless coverage and higher data transfer rate, latest wireless technology extends wireless coverage by 5 times, and eliminates wireless dead spots. EW-7622UMn USB adapter is compatible with IEEE802.11b/g/n wireless standards, and is capable to transfer data at up to 300Mbps when connected with 802.11n wireless devices. The wireless technology used by Edimax EW-7622UMn USB adapter also makes wireless signal travel for longer distance, and provides more reliable wireless connections when comparing with traditional IEEE802.11b/g wireless network.
Features Hardware WPS (Wi-Fi Protected Setup) button
Wi-Fi Protected Setup (WPS) is a new technology designed to establish a secure wireless network in a fast and easy way. If the wireless device you wish to connect supports WPS, Edimax EW-7622UMn USB adapter will establish a secure, encrypted WPA data connection with it. All you need to do is only a simple key press. Edimax EW-7622UMn USB adapter supports both hardware (push button) and software (web page setup) WPS.
Features Multi-language EZmax Setup Wizard
Edimax EW-7622UMn includes an EZmax setup wizard - a setup application available in 16 languages, which will assist you to connect your new EW-7622UMn USB adapter with wireless network in no time.
Compact, Portable Design
Edimax EW-7622UMn wireless USB adapter is compact and portable, makes it become the first choice for mobile users.
USB Stand Improves Wireless Performance
When using Edimax EW-7622UMn wireless USB adapter with the USB stand included in product package, it will provide better wireless performance at no extra cost.
Image gallery
Select any thumbnail below to view a larger image.
Customer reviews read all 1 customer reviews
Write a review for the Edimax 300Mbps Wireless N USB Adapter here!
edimax 300mps usb
Reviewed by Anonymous Review Posted 10/05/2011
Does not give promised speed in my experience. Very disappointed.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
  • Wireless 802.11n standardEdimax EW-7622UMn provides extended wireless coverage and higher data transfer rate, wireless technology extends wireless coverage, and eliminates wireless dead spots. EW-7622UMn USB adapter is compatible with IEEE802.11b/g/n wireless standards, and is capable to transfer data at up to 300Mbps when connected with 802.11n wireless devices. The wireless technology used by Edimax EW-7622UMn USB adapter also makes wireless signal travel for longer distance, and provides more reliable wireless connections when comparing with traditional IEEE802.11b/g wireless network.
  • Features hardware WPS (Wi-Fi Protected Setup) buttonWi-Fi Protected Setup (WPS) is a technology designed to establish a secure wireless network in a fast and easy way. If the wireless device you wish to connect supports WPS, Edimax EW-7622UMn USB adapter will establish a secure, encrypted WPA data connection with it. All you need to do is only a simple key press.
  • Compact, portable designEdimax EW-7622UMn wireless USB adapter is compact and portable, makes it become the first choice for mobile users.
  • USB stand improves wireless performanceWhen using Edimax EW-7622UMn wireless USB adapter with the USB stand, it will provide better wireless performance at no extra cost.
Edimax EW-7622UMn - network adapter
Network adapter
External
Interface (Bus) Type
Hi-Speed USB
2.1 cm x 6.1 cm x 1 cm
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, USB 1.1, USB 2.0, IEEE 802.11n
Linux, Microsoft Windows 2000/XP/Vista/7, Apple MacOS X 10.4.x or later
Network adapter
External
Hi-Speed USB
2.1 cm
6.1 cm
1 cm
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
Aerial
Antenna
Internal integrated
1 x Hi-Speed USB - 4 PIN USB Type A
USB cradle
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
FCC, RoHS
Software Included
EZmax Setup Wizard
0 - 95% (non-condensing)
feature value
Wired / Wireless Wireless
Protocol IEEE 802.11b
Protocol IEEE 802.11g
Protocol IEEE 802.11n
Form Factor External
Compatibility Mac
Compatibility PC
Type Network adapter
Brand Edimax
Stock Status In Stock
Price Range Inc VAT 0 - 50
