Marketing description is not available.
Product Description | Draytek Vigor N61 - network adapter - USB 2.0 | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Dimensions (WxDxH) | 2.7 cm x 8.7 cm x 1.2 cm | Data Link Protocol | 802.11b/g, 802.11n (draft 2.0) | Data Transfer Rate | 300 Mbps | Frequency Band | 2.4 GHz | Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0) | System Requirements | Microsoft Windows Vista / 2000 / XP | Manufacturer Warranty | 1-year warranty |
General | |
Networking | |
Connectivity Technology | Wireless |
Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0) |
Spread Spectrum Method | OFDM, DSSS |
Line Coding Format | CCK, 64 QAM, BPSK, QPSK, 16 QAM |
Features | MIMO technology, Wi-Fi Multimedia (WMM) support |
Aerial | |
Antenna | Internal |
Expansion / Connectivity | |
Connections | 1 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Cables Included | 1 x USB extension cable |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2 |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Vista / 2000 / XP |
Dimensions & Weight | |
Width | 2.7 cm |
Depth | 8.7 cm |
Height | 1.2 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% |
