Click to visit BT.com
Draytek Vigor 2820n Wireless-N Router BT ADSL
Draytek Draytek Vigor 2820n Wireless-N Router BT ADSL
Quicklinx: 4XLFWS00
Mfr#: V2820N
The Vigor 2820 series is DrayTek's flagship premium ADSL router/firewall family. PC Pro says "For business, it's an obvious choice".Compatible with all variants of ADSL the Vigor 2820 can also be used for cable-modem and leased line applications thanks to its additional WAN port (Ethernet). A Gigabit Ethernet port on the LAN side provides high speed connectivity for your server. Security features include content filtering, web application controls and an object based firewall management system.
Image gallery
Select any thumbnail below to view a larger image.
  • Robust and comprehensive firewallSecurity is taken seriously on the Vigor 2820 Series. The firewall features measures for protection against attacks including Dos (Denial of Service) attacks, IP-based attacks and access by unauthorized remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. A DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organizations.
  • Dual-WAN load balancing and backupAs well as the primary ADSL interface, the Vigor 2820 features a secondary WAN port for Internet access. This is an Ethernet interface and can connect to a second ADSL modem, cable modem or any other Ethernet-based Internet feed. The secondary interface can be used either for WAN-Backup or load balancing.
  • Voice-over-IP featuresThe Vigor 2820 Series 'V' models build on the established DrayTek VoIP pedigree by adding even more new features. Twin analog phone ports and an FXO analog line port provide full PSTN and VoIP integration on the same phones, via both the Internet and your regular analog line. The two phones can be used independently and simultaneously for both incoming and outgoing calls.
  • 3G cellular data featuresThe Vigor 2820 Series's USB port can host a compatible 3G modem or cellphone for access to the cellular network for full Internet Access. Most UK networks now provide high speed HSDPA data connections at up to 3.6Mb/s download speed. The 3G connection can be used as your primary/only Internet access, or as backup to your main ADSL line connection. This is not only ideal for homes or offices which don't want to pay fixed line + broadband rental, but also for temporary locations, or those to where fixed lines aren't available.
  • Dial-up backupIf you rely on your Internet connection, you can allow for ADSL failure by adding dial-up backup to your Vigor2820. Dial-up backup uses a 'good old-fashioned' analog modem to dial a backup ISP in the event your ADSL line or ISP fails, either temporarily or for an extended period. The add-on analog modemprovides 'V92' connections which is somewhat slower than your broadband connection but certainly usable for light web browsing, email and all other online activities which you really can't do without.
Draytek Vigor 2820n - wireless router - DSL - 802.11n (draft) - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
Ethernet, ATM, Fast Ethernet, Gigabit Ethernet, IEEE 802.11n (draft)
VPN tunnels : 32
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, AAL5, DHCP, DNS
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Firewall protection, DMZ port, DHCP support, NAT support, Syslog support, Stateful Packet Inspection (SPI), content filtering, dynamic DNS server, E-mail alert, VPN passthrough, firmware upgradable, DDos attack prevention, Quality of Service (QoS)
ANSI T1.413, IEEE 802.1x, IEEE 802.11n (draft), UPnP
16.5 cm x 24.1 cm x 4.4 cm
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
VPN tunnels : 32
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
X.509 certificates, Radio Service Set ID (SSID)
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
WAN : 1 x ADSL2+ - RJ-11 , 3 x 10Base-T/100Base-TX - RJ-45 , 1 x 1000Base-TX - RJ-45 , WAN : 1 x 10Base-T/100Base-TX - RJ-45 , USB : 1 x 4 PIN USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Power adapter - external
10 Watt
16.5 cm
24.1 cm
4.4 cm
FCC
2 years warranty
Service & Support Details
45 °C
10 - 90%
