Click to visit BT.com
Draytek Vigor 2710n SoHo ADSL/2+ Router with Wireless-N BT ADSL
Draytek Draytek Vigor 2710n SoHo ADSL/2+ Router with Wireless-N BT ADSL
11 In stock
Quicklinx: 62HRWS00
Mfr#: V2710N
£124.83
The DrayTek Vigor 2710 Series ADSL2/2+ routers are designed to be the ideal ADSL-sharing and firewall device for to the SoHo (Small Office / Home) user.
They combine compatibility with all UK ADSL line types together with performance, features and price into an attractive, relible and easy-to-use product, with the pedigree and thoughtful design DrayTek are renowned for.
Wireless (WiFi) and VoIP (V Models only) further enhance the flexibility of the router and outgoing VPN makes it ideal as a teleworker router for your home VPN link to your main office.
A new style case for this range provides stylish looks and space saving design, allowing upright desk usage or wall-mounting. Cleverly conceived cable entry points also minimise the overall size of the unit.
The USB port can be used to connect a compatible USB printer to so that PCs on your network (wireless or wired) can all share access to that printer. If you want NAS (Network Attached Storage) you can connect a USB memory stick or USB hard drive to store files for everyone on your LAN or remote users to access by FTP or Windows file sharing.
Note: If you want to connect multiple USB devices at once, you will need to add a powered USB hub (not supplied).
Image gallery
Select any thumbnail below to view a larger image.
Draytek Vigor 2710n - wireless router - DSL - 802.11b/g/n (draft 2.0) - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Network / Transport Protocol
L2TP, IPSec
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Firewall protection, DHCP support, VPN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, E-mail alert, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), Wi-Fi Protected Setup (WPS)
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup, IEEE 802.11n (draft 2.0), UPnP
14.8 cm x 21.6 cm x 5.4 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
L2TP, IPSec
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.5
LAN : 4 x 10Base-T/100Base-TX - RJ-45 , USB : 1 x 4 PIN USB Type A , WAN : 1 x ADSL2+ - RJ-11
Aerial
Aerial
External detachable
Antenna Qty
3
Power adapter - external
10 Watt
14.8 cm
21.6 cm
5.4 cm
FCC
45 °C
10 - 90%
feature value
Type Wireless router
Connection Type ADSL (BT)
Standards Ethernet
Standards Fast Ethernet
Standards IEEE 802.11b
Standards IEEE 802.11g
Standards IEEE 802.11n (draft 2.0)
Rackmount or External External
Brand Draytek
Stock Status In Stock
Price Range Inc VAT 100 - 150
