Click to visit BT.com
Devolo dLAN Highspeed II 85Mbps (3 Pack)
Devolo Devolo dLAN Highspeed II 85Mbps (3 Pack)
3 in stock
Quicklinx: 5KJMWS00
Mfr#: 1437
£75.00
The high-speed HomePlug adapters connects your computers and brings the Internet into every room of the house over the electrical wiring. Now with patented power save mode and new, clearly arranged 3-LED design.With the new devolo dLAN Highspeed Ethernet II, setting up your home network is a breeze - and you will not even have to bother with installing cables. Unlike wireless networks (WLAN), thick walls and long distances make no difference to HomePlug. The HomePlug technology uses the household electrical wiring as if it were a long network cable - offering a range of up to 200 m (656"). Fast and secure surfing on the Internet with high transfer rates of up to 85 Mbps and DESpro encryption. No complex configuration is required for installation: plug the adapter into the power outlet, connect it to your computer via the network cable and you are ready to go! Now you can expand your home network at any power outlet in the house using additional adapters. The user-friendly software allows individual password assignment for even more security.
Image gallery
Select any thumbnail below to view a larger image.
Devolo dLAN Highspeed Ethernet II Network Kit - bridge - desktop
Packaged Quantity
3 (specifications are for single item)
Bridge
Enclosure Type
Desktop
Ethernet, Fast Ethernet, HomePlug 1.0
Data Transfer Rate
85 Mbps
Network / Transport Protocol
TCP/IP
Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug 1.0
AC 120/230 V ( 50/60 Hz )
Linux, Microsoft Windows XP, Microsoft Windows Vista (32/64 bits)
3 years warranty
Packaged Quantity
Bridge
Enclosure Type
Desktop
Wired
Data Transfer Rate
85 Mbps
TCP/IP
Status Indicators
Link activity, link OK
1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug 1.0
Power supply - internal
4.5 Watt
3 x network cable
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 90%
feature value
Packaged Quantity 3
Speed 85Mbps
Connectivity Wired
Brand Devolo
Stock Status In Stock
Price Range Inc VAT 50 - 100
